Transmission Rapid Shifting - 2007 Expedition EL - Ford Truck Enthusiasts Forums
Old 05-21-2017, 10:32 PM
ChuckDFW's Avatar
ChuckDFW
ChuckDFW is offline
ChuckDFW is starting off with a positive reputation.
My 2007 Ford Expedition EL gets confused about what gear it should be in. At certain speeds, the transmission will rapidly shift between two gears. If I turn off the overdrive it seems to get better. There are no OBDII codes.
Any ideas what could cause this?
Old 05-24-2017, 12:18 PM
Beechkid
Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
if you are running at no more than 40 mph, OD should be locked out........................
Stacylynb
01-05-2018 11:12 AM
charlesmoody67
07-10-2017 06:58 PM
Haines25
06-09-2017 10:04 AM
ChuckDFW
05-21-2017 10:30 PM
Powerstoke73
04-10-2016 07:42 PM
Quick Reply: Transmission Rapid Shifting - 2007 Expedition EL
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
