Atlas 40 tune with emissions in AZ
Hi All,
My FICM just went out and I will be sending it to FICMrepair on Monday morning. I wanted to get the Atlas 40 tune while it was there.I live in Maricopa County, AZ and have to go through yearly emissions testingwhich is the three “blip” test. Pedal to the floor three times till it hits therev-limiter. (I HATE that test…)
My questions are:
Will this tune have a negative effect on the emissions test?
Should I get a spare FICM with a stock tune for emissionstesting?
Does anyone else here live in AZ and go through that testwith the Atlas 40 tune?
My truck is an 05 SBCC with 6” lift and 35’s. Also has theBanks 4” cat back system and a punched out cat. All motor updates were doneabout 4 years ago except the head bolts. I had to stop somewhere. haha
Thanks for any replies. This is a great forum with manyhelpful members…
My questions are:
Our test is just a soot test, I believe. I have a spare cat to install if needed, but it has passed the last two years.
My main concern is about the rev-limiter issue. Does the Atlas tune change the limits for any of that stuff, or is that handled through the PCM?
I think that is why AZ uses this test, to stop people from putting tunes on their diesels...
Don't want to over-rev the motor with the new tune and damage stuff...
Hope this helps!
Ed
We do the snap test in Washington. I make sure to roll back the tune to stock and put the cat back in. The Atlas 40 has never caused an issue. Passed every time. Sadly, I am up for testing again as soon as we get back from our adventure.
Just need to stop by the storage unit and catch the cat.
you load the tune. So you should be able to make that adjustment
without loading any tunes. Like say you wanted to make a change to the
revolutions per mile for the tire size and lower the rev limiter.
It's all in the options.
I'm waiting for the day someone posts here or somewhere else that the rev limiter did not work as designed and parts were flying from the side of the block...........that, or it ran like crap after the tests due to something else that would not have normally happened.
EPA my foot..they have their place I realize but some things are a crock of !@#$
Ira Brown
12-19-2014 11:00 AM
trippn4re
23
06-02-2014 04:16 PM
doctorolds
06-01-2007 04:49 PM
89fourx4
12-01-2006 04:29 PM
