Kenwood DDX774BH Receiver Questions - Ford Truck Enthusiasts Forums
Old 05-21-2017, 02:02 AM
SWV10's Avatar
SWV10
SWV10 is offline
SWV10 is gaining momentum as a positive member of FTE.
For: 2016 F350.
with Steering wheel controls, SYNC, Bluetooth, SirusXM, rearview camera, stock am/fm/cd radio, w/o sub.
Kenwood DDX774BH
SiriusXM SXV300 Tuner adapter
Maestro Ar ADS-MRR idatalink
Maestro FO1 Installation Wiring Harness
Metra 95-5812 Radio install kit (Radio mount bracket, extension for AM/FM Antenna)
This entire system was not bought through Crutchfield.
While having all of this spread over the dining room table it really doesn't look to be a challenge to install. The needed wire connections for the speakers are completed. The Wiring Diagram for the Maestro iDatalink is straight forward and shows all of the plugs to be installed clearly.
Connected the Reverse Sensor wire (Purple w/white stripe) to the Maestro wiring harness.
Connected the Ground, 12v power, ign and illumination wires to the Maestro wiring harness.
installed Butt ends to end wires not used in this application.
Next the iDatalink Module needs to be Flashed (online homepage for iDatalink)
Disconnect 12v Battery connection at the Battery then remove stock Radio.
Questions:
SiriusXM, can the Ford Installed Sirius XM Antenna be used with the Kenwood or does the new included SiriusXM Antenna needed to be used?
Can the already installed Ford Mic be used with the Kenwood or does the New Mic need to be wired in?
Does the Ford rear view camera wire plug directly into the back of the Kenwood Receiver or are any additional cables needed to make it work with the Kenwood? ( to view the rear Camera from the stock rear view Mirror to the larger Kenwood screen )
What purpose is the Parking Sensor wire? (light Green Wire)
Old 06-11-2017, 10:02 PM
SWV10's Avatar
SWV10
SWV10 is offline
I haven't been able to get back to this project but I did find the required Sirus XM adapter at around $13(ordered). I'm having no luck though with retaining the backup camera connector to plug into the rear deck of the Kenwood but the Audio install shop says it can be done.
The Bluetooth Mic that is stock in the Ford can Not be used with the Kenwood, a new Mic is included with the install kit and shouldn't be a issue to install it above the drivers sun visor at the top of the windshield.
I would still prefer to do the install myself but if need be, I can have the unit installed for appox $190 or less.
As the project progresses I will update but now I'm getting ready for a upcoming 2 week flyfishing trip, that comes 1st.
Old 06-11-2017, 10:19 PM
SWV10's Avatar
SWV10
SWV10 is offline
The parking sensor wiring is not a issue for me as I am not going to be watching a DVD while driving, talk about a distraction.
Old 07-06-2017, 10:46 PM
SWV10's Avatar
SWV10
SWV10 is offline
ok, the Kenwood is now installed, I did have a audio shop install it. Everything works perfect, I'll post up some pic's tomorrow.
Old 07-07-2017, 08:59 PM
SWV10's Avatar
SWV10
SWV10 is offline
Seems my Ph doesn't work with this Kenwood but I'm not surprised, this ph has been needing to be replaced for some time now. Not a issue to deal with right away as this SD is not my everyday vehicle.
Old 07-30-2017, 03:07 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
DeeDubz is starting off with a positive reputation.
nicely done whats PH? Id like to install myself. Is this something that wayyyy over my head?
Old 07-30-2017, 05:07 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Just remember if you have a S6 and newer Samsung Galaxy...it cant hook up to HDML...these phones dont support MHL. There is an adapter though.
Old 07-31-2017, 02:28 AM
SWV10's Avatar
SWV10
SWV10 is offline
My (PH) Phone was the issue, once upgraded everything works perfect with bluetooth.
Other than the rear view camera hookup I would of installed this Kenwood myself. The Kenwood was a gift, if say it was all bought through Crutchfield then maybe I could of figured out the rear view wiring issue with the help of their Tech section.
Old 07-31-2017, 06:33 PM
DeeDubz's Avatar
DeeDubz
DeeDubz is offline
thats the only thing stopping me right now. I dunno might go get one at best buy and have their goons install. Looks pretty good. did you add a sub or amp?
Old 08-26-2017, 02:15 PM
SWV10's Avatar
SWV10
SWV10 is offline
No, I did not install the sub or amp.
Old 12-28-2017, 09:27 PM
SWV10's Avatar
SWV10
SWV10 is offline
I have noticed some glare on the Kenwood screen, found nothing for aftermarket so I made one. I used Velcro above the unit to attach a shade, this way I can remove the shade when I take in the SD for service. I used a piece of dark firm foam, trimmed it to size I wanted.
The glare in the Pic is from the flash from the camera when taking the pic.
Old 01-02-2018, 09:19 PM
Mastertinner
Mastertinner is offline
Mastertinner is gaining momentum as a positive member of FTE.
I just installed the kenwood dnx574s with a backup camera off amazon in my 2016 f250. Everything works great. I did not hook up the factory xm antenna, but I was able to use the factory mic.
Old 01-04-2018, 11:12 AM
auburngrad
auburngrad is offline
auburngrad is starting off with a positive reputation.
Thanks for this write up.
I am looking at this exact unit for my 2015 250. Not sure when I'll bite the bullet. I would like to save the 200 dollar install and do it myself. I've done others before. This will be the most complicated, as adding the miestro box will be new to me. And I plan on running a back up camera also.
Old 01-04-2018, 03:00 PM
SWV10's Avatar
SWV10
SWV10 is offline
I wanted to do the install myself too but couldn't find any helpful info on the rear camera hookup, youtube only gave me more confusion than the answer I was looking for, so not to screw it up I had the Audio shop install it. The Kenwood Receiver was a gift so paying for the install didn't hurt that much.
Old 01-20-2018, 10:48 AM
itat
itat is offline
itat is starting off with a positive reputation.
How did you get the factory mic to work with your Kenwood HU?
Quick Reply: Kenwood DDX774BH Receiver Questions
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
