a lil help with my 1990150 Lariat
Old 05-20-2017, 02:14 PM
bloodyreaper001's Avatar
bloodyreaper001
bloodyreaper001 is offline
Ok so guys I have a 1990 Ford F-150 XLT Lariat it has the 4.9 liter straight 6 I'm not sure what the transmission is I know it's a standard 5 speed but I'm not sure on exactly what the transmission it has if any if you have a way for me to find that out that would be amazing. Having said that I'm replacing the clutch right now but then I'm looking to increase power and torque and towing ability I was also wondering if anybody had any ideas on how I should go about that thanks for any help guys
Old 05-20-2017, 02:37 PM
R&RFord's Avatar
R&RFord
R&RFord is offline
Assuming the drive train is relatively healthy, a thorough tune up with quality parts. Keep up with regular maintenance. Stick with short tires. Don't do anything that makes the truck heavier, or increases wind resistance. Do not waste money on any bolt one power adders. Have realistic expectations.
Look into your rear end gearing. You are likely running a gear ratio favoring economy over torque. If so, a re-gear is likely your best bang for buck.
Old 05-20-2017, 03:28 PM
Conanski's Avatar
Conanski
Conanski is offline
That would be the Mazda M5.
There isn't much you can do about the first two but gears make a big difference in towing ability. 3.55 would be what I suggest for a good compromize between power and economy with your powertrain and stock tires or something close, if you truck is typical it has 3.08 gears now and that would be a healthy upgrade. To find out what you truck has now find the axle code on the drivers door pillar and post it up, that will decode to show the ratio.
Now the easiest and quickest way to get a different axle ratio is to swap in a complete axle from a wreck, any F150 from 1987-1996 would make a good donor, and it doesn't matter if the truck is 2wd or 4wd the rear end is the same as yours.
Old 05-20-2017, 04:43 PM
bloodyreaper001
Thank you for that i appreciate it now how do we find out in the tranny is in fact a mozda 5 becouse to me that seams a lil odd being that it is a cord now i dont know alot about american cars but i do know mozda are small mostly frount wheel drive trannys
Old 05-20-2017, 08:35 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,344 Likes on 1,061 Posts
What is the trans code on the driver's "B" pillar? Code M is for the Mazda M5OD-R2.
Old 05-31-2017, 01:30 PM
bloodyreaper001
how do i decode this
Old 05-31-2017, 03:08 PM
My4Fordtrucks
The block that says TRANS has a code of "M" under it so it would be the Mazda M5OD-R2 transmission.
Old 05-31-2017, 03:21 PM
bloodyreaper001
Ok thanks for the help any ideas on upgradeing my trans like what i should be looking at when looking at different trans
USAF_EOD
19
03-17-2014 08:48 PM
MKEBoost
2009 - 2014 F150
19
05-16-2012 09:11 PM
icobod
16
09-21-2011 05:40 PM
AJParry89
03-21-2011 12:21 PM
fordpstroke11
1997 - 2003 F150
09-22-2010 06:08 AM
Quick Reply: a lil help with my 1990150 Lariat
