Job 2 Cupholders and Rear USB Ports Upgrade
#108
#111
#115
We’re did you get the plug for the 110v? I am doing the swap from job 1 to 2 need that plug from job 2 and the inverter cables and the plug for the inverter
QUOTE=das_16;17241919]So the rear usb on job 2 trucks are not connected to the radio i confirmed that a long time ago. And I powered it up with just wiring it to the 12v plug. I found this thread on another forum I figured I will post it here with information with part numbers. And the rear cover I got came complete with outlets but it was used they found it for me. I also had to swap plug ends on the 110v plug since it had a different end.
Dual USB cable JL1T-14D202-GA
Dual outlet cover FB53-045N67-A ('16+ Explorer rear of console)
Single outlet cover FB53-R045N22-A ('16+ Explorer inside center console)
Power inverter GU5T-19J211-AA
Wiring connector for inverter WPT-982 (6U2Z-14S411-JB)
Only the 2 outer wires are used for power and ground power (yellow) and ground (black).[/QUOTE]
StephenKnight
15
06-14-2003 01:40 AM
