Job 2 Cupholders and Rear USB Ports Upgrade
#91
So the rear usb on job 2 trucks are not connected to the radio i confirmed that a long time ago. And I powered it up with just wiring it to the 12v plug. I found this thread on another forum I figured I will post it here with information with part numbers. And the rear cover I got came complete with outlets but it was used they found it for me. I also had to swap plug ends on the 110v plug since it had a different end.
Dual USB cable JL1T-14D202-GA
Dual outlet cover FB53-045N67-A ('16+ Explorer rear of console)
Single outlet cover FB53-R045N22-A ('16+ Explorer inside center console)
Power inverter GU5T-19J211-AA
Wiring connector for inverter WPT-982 (6U2Z-14S411-JB)
Only the 2 outer wires are used for power and ground power (yellow) and ground (black).
#93
#94
#98
#105
This one looks like it starts with an HC but I'm not able to read it well. I'm thinking I can do a process of elimination.
