Baby Boomer F250 Build Thread - Page 3 - Ford Truck Enthusiasts Forums
Old 06-02-2017, 12:22 PM
Baby Boomer's Avatar
Baby Boomer
Baby Boomer is offline
Baby Boomer is starting off with a positive reputation.
Originally Posted by JEFFFAFA View Post
LM104949...C7TZ1240A...2" I.D......7/8" thick.
18790.........B6D1244A....2" I.D......11/16" thick.
1966/69 before ser #F30.001 took the 18790. 1969/newer after ser #F30,001 got a different hub and took the LM104949 inner and outer. The bearing cup that was matched with the LM104949 was LM104911. You might have two different hubs.
Thanks
I appreciate your help.
  #32
Old 06-09-2017, 05:49 PM
Baby Boomer
Finally gone the rear end back together last night. The bearings and seal issues were beyond expectations. I guess I better be prepared for the unexpected.
Nice to put at least a few things back together. Encouraging!
Now to turn it around and start disassembly on the front.
  #33
Old 06-11-2017, 08:01 AM
Baby Boomer
Defective seam sealer (installer).
Ok, so after taking the bed to the body shop, it seems like the seams that I filled on the sides will have to be redone. When they tried to sand it with the DA, it only gummed up. So it did not set up correctly. Now they are going to have to cut out part of the seam sealer and lay some new seam sealer on top of it that will harden correctly.
"If it was easy everyone would do it".
  #34
Old 06-12-2017, 08:51 AM
fe390pc's Avatar
fe390pc
fe390pc is online now
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
live and learn. I like how that rear end came out, looks fantastic.
  #35
Old 01-13-2018, 03:32 PM
Baby Boomer
Slowly gaining speed on my rebuild.
Things have been moving pretty slow for a while waiting to get into a shop I rented. Moved in now and Iím hoping things will pick up speed now. (At least as long as the money holds out.)
  #36
Old 01-13-2018, 08:06 PM
Baby Boomer
Passenger side door back from body man.
Looks good with the shaving!
  #37
Old 01-13-2018, 10:34 PM
fe390pc's Avatar
fe390pc
Wow that is a lot of progress!
  #38
Old 02-08-2018, 08:07 PM
Baby Boomer
Starting to run out of things to tear down!
Hope I can remember where all this stuff goes....
Getting the frame ready for blasting. Then paint.
  #39
Old 02-08-2018, 09:01 PM
fe390pc's Avatar
fe390pc
Looks good sitting in that shop!
  #40
Old 02-09-2018, 05:20 PM
Baby Boomer
Thanks. A labor of love!
  #41
Old 02-10-2018, 04:57 PM
Baby Boomer
Had a good day and got a little closer.
Everything off that will come off, except the grease and thatís next....
  #42
Old 02-10-2018, 04:58 PM
Baby Boomer
What’s the trick to remove those core support mounts?
  #43
Old 02-10-2018, 05:39 PM
Coastal68's Avatar
Coastal68
Coastal68 is offline
Coastal68 is gaining momentum as a positive member of FTE.Coastal68 is gaining momentum as a positive member of FTE.
Originally Posted by Baby Boomer View Post
Whatís the trick to remove those core support mounts?
https://www.ford-trucks.com/forums/1...-hardware.html
  #44
Old 02-10-2018, 08:55 PM
fe390pc's Avatar
fe390pc
A sawzall and some good blades is what I have used.
  #45
Old 05-21-2018, 08:01 PM
Baby Boomer
Got the frame painted this weekend!
Really like the way this turned out....
Baby Boomer
WTB - Parts & other
07-23-2017 07:30 AM
Baby Boomer
WTB - Parts & other
06-16-2017 05:05 AM
Baby Boomer
Ford Truck Parts for Sale
06-15-2017 05:44 AM
Baby Boomer
06-06-2017 10:05 PM
Baby Boomer
12-05-2016 10:00 AM
Quick Reply: Baby Boomer F250 Build Thread
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
