1994 F250 Turbo Diesel no gears
Hi, my 1994 F250 Turbo Diesel 4x4 will not go into gear.
It will go into PARK and neutral.
I was driving with transfer case in 2H and Hubs FREE doing hwy speed when it just slipped out, nothing there at all.
Speedo went nuts and buried the needle which is still in that position.
Any ideas??
Any ideas??
Could this be an electrical issue, like a bad ground or power wire?
As the truck did have a 10-15 min bout with speedo going crazy then eventually maxxing out.
I can fire it up and it says I'm doing max speed.
Going through gears is smooth no grinding.
Can the Transfercase be stuck in Neutrel? Can't see thatI drove after putting it back into 2H.
on
You should be able to remove the trans relay and find a couple gears.This will cut power to the trans control unit.Then the truck should have reverse and (high gear in D but don't frig with this) and 2nd gear in both the manual 1 and 2 positions.
This here will cut the power to the trans controller that is freaked out and confused from the 100 MPH + speed signal which is blocking all your gears.......this is admittingly a guess but seems like a logical one.
If this is the case,which most likely will be,then the odds are high that after you replace the broken speedometer,that everything will be normal again,when you put the relay back in too of course.
PSOM info is here.Here you can find info to possibly fixing it yourself,send it in for repair or replace it.
https://www.ford-trucks.com/forums/1...s-but-why.html
