'64 clutch replacement
Old May 18, 2017 | 02:00 PM
DoggedTired's Avatar
DoggedTired
On my '64 I replaced the clutch on the 3 speed trans and after reassembling everything the clutch pedal now goes all the way to the floor. It is almost like I need a longer clutch release rod from the z-bar to the clutch fork. Could there be enough difference between the old/new clutches that would give me that much extra play or did I assemble something incorrectly? Was just going to make a longer rod but really would rather make sure I put it all together correctly first!
Old May 18, 2017 | 03:33 PM
charliemccraney's Avatar
charliemccraney
Why did you replace the clutch?
Is the replacement like original or a more modern diaphragm style?
Old May 18, 2017 | 03:37 PM
DoggedTired
When taking off from a stop it would buck and jerk and everyone said the clutch was burned out. Replaced it with the "same looking" clutch and had the flywheel turn as it had cracks and was very glazed looking.
Old May 18, 2017 | 03:51 PM
charliemccraney
If the flywheel had cracks, then you need to replace the flywheel. It looks pretty now but it is still cracked and they will be visible again soon. The '64 and earlier flywheels are not as robust as they are on newer engines. Once they've cracked, they're done.
For the problem at hand, pull the inspection cover to ensure that the fork is in the throwout bearing groove and on the pivot stud correctly. Make sure the bellhousing is flush with the rear of the block. From there, inspect all components of the linkage for damage. There are bushings on the linkage rod from the pedal to the z-bar. Those are usually gone, allowing wear and eventually the rod breaks. There are bushings for the z-bar. All of those can contribute to inadequate available adjustment.
Old May 19, 2017 | 09:44 AM
DoggedTired
In putting everything back together I did see that the zbar bushing on the engine side is missing so that would account for some play but not as much as it seems to have. The fork and the throwout bearing are lined up.
Old May 19, 2017 | 10:10 AM
charliemccraney
Missing bushings lead to component failure. Make sure the Z-bar is not bending or tearing as a result of wear because of that missing bushing. Replace that bushing ASAP.
Pwnm30rdi3
Jun 6, 2012 06:05 AM
DEAN BEAN
15
May 31, 2009 09:50 AM
1957F100
Jul 24, 2008 01:21 PM
The Grinch
Dec 17, 2004 03:51 PM
perrymb
Mar 11, 2001 08:43 AM
