O ring fried on injector: What was the cause of this? - Ford Truck Enthusiasts Forums
Old 05-17-2017, 12:05 PM
jstihl jstihl is offline
jstihl is starting off with a positive reputation.
I have been having alot of problems with my truck consuming oil. I had a mechanic put all new injectors on driver side, 6 months later truck started consuming alot of oil. Then mechanic told me it was probably the other bank. So i changed the injectors on the passenger bank and still had oil consumption problems. So i decided to take apart the drivers side bank that mechanic did and found a burnt up O ring on one side of injector 6. Is the cause of this from using cheap o rings? is it ok to put alliant orings back on the injector and pop it back in?
Old 05-17-2017, 12:10 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Yes put Alliant o-rings back on. I would inspect that cup for damage but the mechanic probably didn't tighten that inject right. That or he put them in dry. Should of checked his work before installing the other bank. Good luck and report back after driving for a while. Also retorq all injectors to make sure they are at 120 inch pounds. Some even go to 130 inch pounds. If there loose at all, also do the other side. Don't for get the copper gasket as well.
Old 05-17-2017, 12:12 PM
tjmike tjmike is offline
tjmike is starting off with a positive reputation.
I suspect more info would be helpful:
A photo would be good. Is it the bottom o-ring? Did it seem to be properly torqued down? What is the condition of the copper gasket?
Old 05-17-2017, 12:34 PM
hey mike, I am posting pics now but it wasn't the bottom O ring it was the middle pink o-ring. The copper washer look fine. That's why I thought it was kind of odd. Please check out pics and let me know what you think thank you
Also the idiot mechanic put in Autolite glow plugs. The one that was next to this injector was hard to get out I believe it was swollen period going back with Motorcraft glow plugs and allianr o rings
Old 05-17-2017, 12:55 PM
Yes, change all glow plugs. How's your fuel filter look?
Old 05-17-2017, 01:00 PM
Tugly's Avatar
Tugly Tugly is online now
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Dry install. You'd be better off doing you own work on the truck... maybe your mechanic can handle the Fisher Price car in the background.
I suggest you search for the term "hot torque" and do that before putting the VCs back on.
Old 05-17-2017, 01:05 PM
hey tugly, is it possible that the crappy Autolite glow plug shorted out or something and swole up then overheated that one o ring through the injector cup?
Old 05-17-2017, 01:06 PM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
I'm no expert but my driveway mechanic gut is telling me that looks like a pinched o-ring.
Old 05-17-2017, 01:08 PM
Dan V Dan V is offline
Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.
Quote:
No.....it's caused by faulty install.
Old 05-17-2017, 01:09 PM
JoeF250 JoeF250 is offline
JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.
I'd hazard the guess that your "mechanic" installed the injectors dry, or pretty dry. As long as you're in there I'd check them all. Dip the new orings in oil before you put em in the injector. Slather the whole injector in oil before you drop them in. And don't give your "mechanic" any more of your money. At least not on your 7.3, maybe he's good at gassers or something, but this clearly isn't his forte.
Old 05-17-2017, 01:19 PM
Quote:
I couldn't agree more Joe. It has been a long painstaking process trying to figure this out and it ends up being a little o-ring that they obviously didn't do a good job of installing.. very aggravating comma I can't understand how a driveway mechanic like myself can do a better job than someone who does it for a living. Well thanks again to all the brothers on FTE!
Old 05-17-2017, 01:22 PM
I'm going to change the filter in the fuel bowl. Do I just have to drain the fuel bowl out put the fuel filter in, and just turn the key on and off a couple of times to fill the fuel bowl?
Old 05-17-2017, 01:29 PM
The Brad The Brad is online now
The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.
Yes, that'll do it.
Old 05-17-2017, 01:32 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Another cautionary tale
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
Dude....run......seriously just.......RUN!!!!! I...SEE...AUTOLIGHTS!!!!!!!
I am in agreement here, if your Fisher price car has a problem take it to the mechanic, I don't think the guy (gal??) knows a single thing about Diesels, I can bet you they are a newer mechanic trained on more modern cars and trucks and not the now status dinosaur 7.3L Diesel....
Old 05-17-2017, 01:36 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Being that bad I would do the oring and glow plugs and run a few tanks of fuel through it before I change the fuel filter. You have lots of oil in the tank, the new filter will just get oily too.
2006 ford f150 misfire/poor accelleration fixed hofec1 2004 - 2008 F150 32 08-16-2017 11:23 AM
Burning alot of oil?? Help jstihl 1999 - 2003 7.3L Power Stroke Diesel 88 05-07-2017 04:06 PM
MISFIRE WITH NO CEL DERREKCREWS 1997 - 2003 F150 7 08-30-2016 07:40 PM
Does the CDR Valve effect oil pressure? LordKamakazi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 05-02-2016 12:23 PM
1999 7.3 Powerstroke lost right hand bank, now truck cranks but wont start CelticFox 1999 - 2003 7.3L Power Stroke Diesel 16 02-21-2016 06:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
