Towing a large 5th Wheel with F-250
#46
#47
And I'll gladly go 62mph in a 65mph zone on a 3 lane higher when I'm traveling in the far right lane. Thanks for letting me know going 15mph over the speed limit is safer.
#48
F250 didn't have the helper spring that the F350 had. The F350 had the 4" blocks where the F250 had 2". Ford towards the 2015 model year decided to put the 4" blocks on some of the F250s and nobody could figure out what was causing SOME of them to have the blocks and others not to. I remember members walking the lots and seeing both size blocks on F250s on the same lot.
Yes same axles, same diff, same brakes etc. But not the overload spring or the blocks on the 11-14.. I don't remember when in the 15s that they started putting the same blocks on.
You're not reading. I already stated all that. The blocks came later in the generation but certainly don't effect towing. The overload comes on the 250 if you get the camper pkg.
As to the brakes, yes, they are identical. A 2012 SRW 350 with vacuum boost brakes is identical to a 2011 F250 but rated to 1.5k more. Keep trying but you won't find a difference in physical ability.
As to tires, you need better tires. Running ST tires will get your family killed a lot quicker than my ratings.
#49
I'm done going back and forth and crapping on someone else's thread. You stated a reply.. I proved that reply incorrect. Have a fantastic night..
#50
Your post with this quote in it...
Is what I responded to and I've already proven that the 11-16 is not physically identical. You can try to twist it around any way you like. That reply you wrote was what I replied to and quoted. And no where in there did you discuss blocks, helper springs, adding "options" to the trucks OR brakes.
I am having a fantastic night. I sincerely hope you do the same. Bye Felicia...
#51
#52
Well hopefully a storm isn't brewing? But you know the tiny Toyo Tundra Towed the Space Shuttle, right!
But my two cents says you want a larger more capable dually truck to comfortably pull, tow and control your load, especially if a mishap should occur. But then again some prefer the Tail wagging the Dog.
But this much I guarantee, if you ever get into ****storm so to speak accident pulling a large trailer, the next time around you will have the most capable tow vehicle around!
#54
I know that you know this, but for others reading this thread, some ST tires are excellent. The Sailun S637 tires I have are either the #1 or #2 tire in the 235/8/r16 LR-G class.
#55
#56
Factory tow ratings are a good guideline but they're hardly a towing 'bible'
I remember one year when Ford upped their towing ability on the F150 by nearly a 1,000 lbs, so Dodge, without changing a blessed thing, upped theirs 1,000 lbs.
Chevrolet pulls stuff like that all the time. And Ford is no innocent bystander.
My 2013 F-150 with the 5.0L V8 has the same, exact towing limits imposed on it as (get this) the 4.6L it replaced. A bunch more HP and Torque, but the same towing numbers. gotcha. And, in my year, going from a 3:31 to a 3:55 gives you 2,000lbs more towing capacity. Yeah, right. What did Santa bring you for Christmas......
Then, when Ford came out with the two new motors at the same time (the EcoBeast and the Coyote V8) they sandbagged the V8. It was making more HP than the EB. Not nearly as much torque, but more HP. Now, all of the sudden, it jumps 25 HP because they 'tuned' it more gooder and put different cams in it. sure
Coincidence? Right. And I promise I'll respect you in the morning.....
The factory guidelines are a good starting point but -- That's about it.
I'll take the word of real world, real people every time over what the factory says.
It's why I'm here. Anybody can read the factory spec sheet
#58
http://onlinetowingguide.com/pdfs/StateTowingLaws.pdf
I was towing my 5er at 62 mph this weekend and I was passed by a 5th wheel probably doing at least 75 Mph. 5 minutes later he was off the side of the road with a blowout shredded tire which totally tore up fender area.
#59
According to this list the speed limit for trailers in your state is 55 mph.
I was towing my 5er at 62 mph this weekend and I was passed by a 5th wheel probobly doing at least 75 Mph. 5 minutes later he was off the side of the road with a blowout shredded tire which totally tore up fender area.
#60
