Looking for 1951-52 F8
Not sure what your skill level is, but here is a SQHD bogey with torsion bar suspension. Seems like a reasonable price. Has air brakes though.
https://www.nexttruckonline.com/sear...45&s-type=part
Looks good from the picture pilot31. Are you restoring it to factory. Same engine and interior. I'm been around cars and trucks as my father was a mechanic so it's in my blood. But I don't know much about big trucks (semis). Let alone any laws. So there is a lot I will need to lean. Does anyone know of a detailed drawing or breakdown of the f7 or F8. I'm looking for size like wheelbase and overall for the different frames. As well as cab sizes. Mostly width door to door.
I'll try to get a door to door measurement in the next day or two.
Yes same engine and trans. Has original interior. No headliner yet. This truck has the 317 ci lincoln y block. Earlier F-7/8s had a 337 flathead. My truck has a non overdrive 5speed transmission and a two speed rear axle. Original color of the truck was meadow green, but as it was a fire truck there is a chance it never was painted at all. I looked at every nook and cranny and didn't find any green. The cabs on all f-1 to f-8 trucks are the same believe it or not! Although the 52 F-7/8s have a removable panel in the floor on the passengers side as the battery was moved under the cab on the frame rail.
Cover page.
2 speed axle works with a switch on the shifter. Push in, its low range; pull out and let off the gas, it goes to high range.
Saw this on craigslist and I remembered this thread. In Des Moines.
This isn't my truck and I am in no way connected to the seller.
https://desmoines.craigslist.org/cto/6130408273.html
Isnt it. Hell, I kinda want it! Would make a badass toy hauler. Good question. It's an hour south of me...may go check it out just to see it in person. Could get dangerous though
-Sam
#28
#29
#30
Lotta unique features on this one. Probably an F-6, with either a Truckstell, Trucktor, Thornton, Fabco, or Grico tandem kit. The sun roof is really unique. The tandem conversion got rid of the stock widow makers and substituted locking side ring Budd or K-H wheels at the rear, and Motor Wheel Corporation Spoksteel brand wheels up front. This is a truck worth saving. Stu
