Need opinions on New Headboard UPDATE: it is finished!
I have been planning on building this headboard for my 55 F350 for months. I bought the boards last fall, painted them this winter but now I am getting close.
I need to know if I should build the headboard so it is just below the rear window or so it is just below the bodyline on the cab.
The headboard as it was when I bought it, above teh bottom of the back window:
The headboard as it is now after I cut off one of the 14" oak boards.
Choice 'A': high headboard just below the rear window
Choice 'B': low headboard just below the body line.
So let me know: 'A' high or 'B' low.
Disregard the two pieces of wood sticking up. They are just stringers holding the boards together until I bolt the boards to the stakes. And, yes, I know the headboard is uneven. The left side is sitting on a round bolt head that I will take care of later.
Thanks!
Thanks!
I'd go with "B" as well. The step down from the headboard to the side rail is about the same as the step down you have on the side rails toward the back of the truck. I like things to be symmetrical. Maybe you could add radius cut corners to the headboard to duplicate the curve you have going on with the sideboard step down.
Jim
Jim
I like the stock stake bed configuration. I rebuilt the original HB on Missy Green and have the same stock dimensions on Blue. Standard 5/4 deck boards are very close to the original board dimensions and are plenty heavy. For the rare time I hauled something that would get thru the voids in the headboard, I had a piece of plywood that I would screw to the headboard. I buit a set of solid sideboards for use when hauling gravel, rock, etc.
Bob Jones had the dimensions on his site. If you like, I can take pictures. Somewhere on this site, there are fairly detailed pictures of MG.
Thanks.
I think that it all depends upon what you are doing with the truck. Headboards are meant to protect the cab and from the pictures that I have seen that you have posted you use your truck to haul things. So I would vote for A but with the corners rounded as John suggested. Sorry but here is a crude mod of your original picture.
Could you round off the headboard in photo B? Thanks!
