Braided Brake Hoses... ?
I'm in New Jersey where they salt like crazy. I upkeep like crazy on my 2004 and all my hardliner etc are perfect. Three years ago I upgraded to Russell braided lines and they have zero signs of rust or corrosion. When I did the lines I did another full flush and adjusted the booster push rod and now my f350 will literally stop on a dim
I don't think you can buy them. Brake lines aren't meant to be rigged up so I doubt you can get them. You can probably get a hydraulic fitting but I'm not sure if it will be rated for the strength and corrosiveness of brake fluid.
I went with Crown custom hoses from KLM Performance. Hoses needed modification, didn't fit well, took way too long, and overall don't seem well made. Steer clear of Crown...
Ordered a cheaper set from Skyjacker (which they insisted were the correct set for my truck...nope). Spent about 25 minutes on the phone with those jokers and they kept transferring me all over the place. Sent them back and ordered the set from PMF Suspension and they will be here in about a week. should have done this in the first place and I would have had the truck fixed by now. Lessons learned...buy once, cry once ;-)
PA_Echo350
05-12-2016 05:51 AM
hasteranger
10-01-2015 11:28 PM
