Out of answers
Could be a cut o-ring on an injector or the ipr. Classic hot-die or hot-no-start cause.
This is the latest CPS that should be used. Motorcraft Cam Position Sensor CPS 94-03
It's very likely. If you can get live data or check codes that would help to know what is going on.
I'm sure a little cold water splashes the underside of the engine, mostly the pan and accessories. It sure is a lot different than pouring the ice water straight into the valley of the engine.
Secondly, I don't think this test would even do anything. The problem is hot thin oil getting by a worn or damaged o-ring. Have you even tried this "test" to see if it actually works?
Thirdly, the o-rings for the IPR valve are only like $14. Why risk cracking a block with ice water for $14? If you can't figure out if that is the problem or not, its way better to just change the o-rings than douse your hot engine with ice water.
#29
#30
