DANA 60 5x5.5 conversion
Old 05-15-2017, 07:13 AM
Zacbkennedy's Avatar
Zacbkennedy
Zacbkennedy is offline
I have a 5x5.5 Dana 60 with drums on my rear end. When I put the independent front suspension on it changed the front to a 5x4.5. I matched the rear with wheels spacers. My problem now is that I just changed wheels and they're a tad bit wider and there's a small clearance issue with the bed on bumps. So by getting rid of the wheels spacers it should suck the wheels in enough for clearance. But then my problem would be the wheels don't match the studs. Is there a way to convert the rear to 5x4.5 in any way shape or form. I'd like to keep the axle and not have to swap it.
Old 05-15-2017, 07:16 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
You could have your axles re-drilled with the smaller bolt pattern, or order new axles with the correct bolt pattern. Moser would be my first call.
Old 05-15-2017, 07:34 AM
good to doo's Avatar
good to doo
good to doo is offline
Put a 9" in instead, then you could redrill the holes.
Old 05-15-2017, 07:51 AM
Zacbkennedy
Trying my best not to swap to 9" or another axle. Unless it's just the axle shafts. I know you can get rotors re drilled. Does it work the same with drums? Would it be easier to swap to rotors and have those re drilled?
Old 05-15-2017, 08:19 AM
good to doo
I don,t think you can redrill the dana 60. Also that diff you have is very old, probably from the 60,s. I have only ever seen 1 of those. Do you know if its a full floater?
Old 05-15-2017, 10:09 AM
Zacbkennedy
I don't know if it's a full floater. I have the diff tag still and the dom number that is stamped on the axle I can check those when I get home. If that doesn't tell me how can I find out. Thanks for the responses yall
Old 05-15-2017, 10:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Zacbkennedy
I have a 5x5.5 Dana 60...
No such thing as an F100 w/a Dana 60 rear axle. Dana 60 (8 lug wheels on a 6.50" bolt circle) rear axle only installed in F250's and 1979 F350 4WD's.
5 lug wheels on a 5.50" bolt circle: 1963/66 F100 with optional Dana 60.2 .. 1966/69 F100 with optional Dana 60.3
Old 05-15-2017, 10:37 AM
Zacbkennedy
Understood. Not arguing. Just saying the diff tag says it's a Dana 60 the dom stamp says it's a Dana 60 so I'm gonna go with it's a Dana 60. Whether it came factory or not that's what's under there.
Old 05-15-2017, 11:21 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
I would just take your axles to a machine shop and have them re-drill the holes for the lugs.
Any reputable machine shop should be able to do this for you for a fairly low cost. The biggest factor to re-drilling is to firstly get everything centered... then secondly, to get the new holes at the correct spots so that the rotation of the axle isn't off-balance due to the existing holes.
The ol' measure twice cut once method should do the trick
EDIT: Make sure you tell the machine shop the correct side of hole you want drilled so you don't have to swap out your studs for something different - I would use the exact same size of stud (factory size) if possible because it keeps things consistent.
Old 05-15-2017, 02:35 PM
Zacbkennedy
It looks like getting them re-drilled would be the best option. For those that say they can't be drilled to a smaller bolt pattern, why is that? Curious before I tank them off and call a machine shop.
Old 05-15-2017, 05:46 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Total guess, but here goes...
I would imagine that it has to do with the structural integrity and overall capacity of the axle to safely handle the load from the lug studs.
You're removing material from a piece of metal that's intended to hold one quarter of the entire load the vehicle exerts (weight + movement). Removing material weakens it substantially... thereby increasing the chances of something breaking or going wrong in the future.
I don't think it's a matter of "you can't", it's a matter of "it's not recommended".
Old 05-15-2017, 07:03 PM
good to doo
To tell if its a full floater, it will have bolts holding the axel in, then the axel can come out. That has nothing to do with holding the wheel on. Next step is to remove the large nuts under the axel(2 of them) the outer wheel bearing is next. Then the drum and hub assembly can come off.Thats where the wheel mounts. It may be possible to redrill those 2 parts.
Old 05-15-2017, 08:37 PM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Old 05-15-2017, 08:44 PM
Zacbkennedy
Looks like I'll be pulling it apart this weekend to find out if it's a floater or not and then go from there.
On the topic of the structure, and the ability to even get the axle drilled out. I would weld up the previous holes. To hopefully add some of that structure back. Does that seem reasonable?
Old 05-15-2017, 10:15 PM
54Hydro's Avatar
54Hydro
54Hydro is offline
Ok, just to clear things up. Do you have a full floater or a semi floater?
If you have an 8 lug full floater as some people have assumed in their replies, redrilling them won't work.
If you have a semi floater then redrill them. There are plenty of high horsepower dragsters running 9 inch, 10 inch, Dana 60, and others with "lightening holes" drilled in the flanges. Just have the holes placed half way between the existing ones. Just remember, what you do to the axles you will have to do to the brakes as well.
Quick Reply: DANA 60 5x5.5 conversion
