Front end wander, where to go next - Ford Truck Enthusiasts Forums
Old 05-14-2017, 05:58 PM
reamer's Avatar
reamer
reamer is offline
reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.
Iv'e done every bushing in my 4x4 IFS, (From radius arms forward), New ball joints, universals, tie rod ends, link is tight, wheel bearings, New Red-Head steering box, Welded the box frame mount, Rag joint and slipshaft are tight, Steering wheel-wheel bearing is all tight and had the alignment done. All in "Spec" and she still wanders on the road.
But in it's defense I can see the right front tire is not standing vertical, making me suspect something's bent, just not sure how to check if it is a spindle or the right side axle tube.....
reamer
Old 05-14-2017, 06:00 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.
But in it's defense I can see the right front tire is not standing vertical.
How can that be
Dave ----
Old 05-14-2017, 06:23 PM
reamer's Avatar
reamer
reamer is offline
makes me wonder, the truck did spend the first 20 years of it's life hauling around a 7.5' Fisher plow.
With the plow on, the tops of the front tires were tilting in.
Pulled the plow and frame off and the front tires looked like a farm tractor, top of the tries tilting out.
Installed HD springs and there are 4 degree shims in there now.......
Old 05-15-2017, 11:03 AM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
CountryBumkin has a very good reputation on FTE.CountryBumkin has a very good reputation on FTE.CountryBumkin has a very good reputation on FTE.CountryBumkin has a very good reputation on FTE.
If you use some "adjustable radius arm bushings" (for Caster adjustment) you may be able to get everything back in alignment. Of course there are Camber adjustment bushings too. Up to about 2.5 degrees.
If you already have a +2.5 in there, and you need more positive camber, a leveling kit (coil spring spacer) will add some positive camber.
I know you posted your alignment specs in the other thread, but I forget know what direction you need.
Old 05-15-2017, 08:56 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
You just paid to have to aligned. The tire should not be angled, and it should not wander. Take it back or take it somewhere and pay them to fix it, not to just put it on their machine and then tell you they "aligned" it. Demand to see the computer printout from the alignment machine.
Old 05-15-2017, 10:18 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.Gary Lewis has a spectacular reputation.
Amen! If the tires are visibly tilting then it isn't in spec and they didn't do their job.
Old 05-15-2017, 11:43 PM
yardbird's Avatar
yardbird
yardbird is online now
yardbird is gaining momentum as a positive member of FTE.
Check your wheel bearings now that you have driven it a while. Loose bearings will cause terrible wander. I assume you replaced the pitman arm end also.
Racerguy
1999 to 2016 Super Duty
763
07-10-2018 02:35 PM
reamer
18
04-21-2017 06:34 PM
yourofficesupplier
09-11-2016 07:17 PM
Boomer89
08-30-2016 10:46 AM
reamer
06-03-2016 08:29 AM
Quick Reply: Front end wander, where to go next
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
