Running rough after oil and filter change and fuel filters
Did my oil change last night and filter swapped both fuel filters on my 04 f350 started it up last night drove it a little bit and she was fine. Went to start her up this morning and she was pissy so I drove her a bit once warm and she feels like there is a dead cylinder maybe?? Any help from y'all would be appreciated.
The filters are motorcraft oil and fuel. I checked all three filter housing and o rings they seem to be in good shape to me. Could it be air in the fuel system? And if so how long could it take to get out. I've driven it about 4 miles today and no change she still runs rough. I've removed all three filters again and reinstalled them primed the **** out of the fuel system. Could there be more air in there because I keep taking the filters off?
When I cycle, I do it until the pump stops. Which I can also indicate by watching my FP gauge. But you can listen for the pump to stop as well.
In your signature it says you use 10W-30 and you put in Archoil with your oil change..... Is this correct? Is this what you did on this oil change?
