Is this possible? Fuel pressure....
#31
Gotcha, that's why I haven't driven it for 2 weeks, even though it's running like it was before... I'm nervous damage to the injectors has already been done but I'm crossing my fingers. That kit from riffraff doesn't have the bushing I need but they have the entire kit for $62, so that's my plan.
#32
I didn't do it... this truck is new to me. The PO did the kit last year but couldn't remember what orings or anything were with it. I'm guessing he got the $40 kit and thought he didn't need the old bushing and was part of the mod. On the other hand, I really don't know, cause the cover looks new and he seems like the kind of guy to buy the most expensive. Either way it's not in now and really hoping it fixes my issue and didn't damage 1 year old oem injectors he had put in.
#33
#34
#35
That sucks brother, this will definitely fix the pressure issue, let's hope the injectors are ok but I don't have much hope. Just be sure once you reestablish the fuel pressure that if it runs rough and is billowing white smoke don't run it because you could hydrolock the engine with fuel and that is a bad deal.
#36
#37
Alrighty, I will watch for that. If it seems to run normal will a shop with proper scanners able to check individual injectors for spray output, integrity, etc? I'm have got the name of a couple local shops that are highly reputable and think I want to take it in and have a "once over" done so I know more what I'm working with.
#38
Cool, well I think I'm good then cause the other day when I started it to check the fuel pressure it didn't smoke and seemed as strong and smooth as it did when I first test drive it... however, I didn't put a load on it.
#39
#40
The whole kit with the cover and rubber sleeve is the part they said was a restricted item. The oring kit w/spring they could get but was still $70, would take 2 days and I'm sure doesn't have the part I need unfortunately.
Im going to call a guy at a shop I spoke with and see if they might have it as it seems some fuel bowls don't need/use the rubber sleeve. Maybe they have spares around.
#41
Upgraded fuel pressure regulator kit (w/ cover): 3C3Z-9T517-AG (1843065C98)
Fuel Pressure Regulator "Spring and Reseal Kit Only" 6E7Z-9C165-B (1854267C94)
Fuel Pressure Regulator "Spring and Reseal Kit Only" for E-Series: 4C2Z-9T517-AA
Fuel Pressure Regulator " Reseal Kit Only" - NO SPRING: 3C3Z-9C165-AA
Fuel pressure regulator cover gasket ("o ring") seal: 3C3Z-9C065-AA
#42
#43
#44
SturgeonHunter
04-24-2010 02:45 PM
ktahelton
30
08-25-2007 08:47 AM
