Testing EGR - What is normal pressure? White smoke
Old 05-14-2017, 12:02 PM
kidoo's Avatar
kidoo
kidoo is offline
Here is the valve would thid indicate a bad EGR? I do not drive much wit the truck and it's been sitting for the winter. Black stuff at the tip of the valve was mostly kind of dry / humid, it was humid at the upper portion of the valve as you see and mostly only on one side.
Old 05-14-2017, 12:20 PM
Brotherbillstruck's Avatar
Brotherbillstruck
Brotherbillstruck is offline
I think park nose down overnight then look into the egr valve hole and look for accumulating fluid. That fluid should not be there.
Old 05-14-2017, 01:33 PM
kidoo's Avatar
kidoo
kidoo is offline
Ok, nose down, I will try that, got find a spot to do that. After a test drive cold, between 125 and 160 F, I floored it a couple of time and all I got was 5 PSI. Came back home and after 3/4 hour, I still had 4 PSI.
I did not see any white smoke this time after sitting for the night.
I will do a few more test.
Old 05-14-2017, 02:25 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
For nose down you could just use jack stands on the rear axle.
Old 05-14-2017, 04:00 PM
kidoo's Avatar
kidoo
kidoo is offline
Another test drive: Normal driving, around 7 to 8 PSI at WOT.
Floor it while going uphill, 10 to 12 PSI at WOT, aroutnd 200 F.
darisb
09-01-2017 12:48 PM
DieselVol
06-11-2013 03:21 PM
bismic
08-26-2011 08:53 PM
jobey
04-14-2010 07:17 PM
Robbgt
02-05-2008 08:48 AM
Quick Reply: Testing EGR - What is normal pressure? White smoke
