1959 f100 4wd Front disk brakes available!!!
Last month for the first time I saw a front disk brake kits available on Ebay. Ordered it today, should be here early next week. Will update all you guys with 59-66 f100 closed nuckle trucks on how it works. Am running 285 75 r16 tires, and right now there is no such thing as a panic stop,
Marc
Marc
Disk brakes
Sorry guys, my Dad passed away at the end of April, have been busy going thru stuff to help stepmom sell house. I opened the boxes, looks very straight forward. The good thing is that replacement parts other than brackets are readily available. I have a vacuum leak I need to find, and timing, carb adjustments before I start with the brakes. Considering going back to original brake master to set up brakes. That way I won't have to find vacuum leak first. Won't be able to get to it for several weeks
Marc
Marc
Finally got kit installed. Really good customer service. I called him up, couldn't find instructions, insisted to him that I never got them. He told me patiently that he puts the kits together himself and has a checkoff to make sure kit is complete.....sure enough, instructions flipped out of box when I unloaded them from attic. Kit was an easy bolt on. Needed to buff spindles with Emory cloth for bearings to slide on spindle. Brake lines needed backing nut ground down an 1/8th of an inch to extend line thru the frame. (These older trucks have thicker frames). Waiting for valve cover gaskets to take for test drive. Marc
Passenger side caliper mounts at 10 o'clock position, driver side at 2 o'clock
Drivers side
Drivers side
Update
Booster and master cylinder too small, front brakes not fully applying. Have tried switching to another corvette master cylinder without success. Currently removing booster and using adapter plate and linkage with a master cylinder out of a 79 Lincoln with a 1 1/8 bore. Will let you know if any better
Marc
Marc
