Explorer sport shudder at 55mph
Hey everyone, I haven't posted in hear before and didn't find anything similar to my problem doing a search so I thought I would start a thread.
I have a 2014 explorer sport with the 3.5 ecoboost. I have an issue with a shudder/ jerk sensation when doing between 50 at 60 in 6th gear. Its very slight and is only noticeable on smooth roads (which in central Texas there aren't a lot of.) Typically happens on slight acceleration or climbing hills. It has been to the dealership several times and they can't figure it out. Only happens at those speeds around 1500 rpm in 6th gear. Nothing above 60 and nothing below 50 really. Its just noticeable enough for me to be annoying.
Dealership's first solution was a new PTU for the all wheel drive. Next solution was to completely remove transmission software and then reinstall and have it go through the learning process. Neither "fix" worked.
Has anyone had similar experiences and had a fix for it? I have searched google and found a few similar problems but on f150s with the ecoboost.
I haven't changed it into any of the other drive modes because it is only happening at cruising speed between 50 at 60 in 6th gear. If i manually downshift to 5th the problem seems to go away. Once it is above 60 there are no issues. The dealership recently thought it could be the axle shafts, they said they have heard of some of them being out of balance and causing an issue. My comment was, if that is the case, then it should be happening in other gears, not just 6th...
The explorer has about 31k on it. It doesn't seem to be getting any worse. Its just a weird little shudder, almost like it is slipping but that doesn't seem to be the case.
If it is a torque converter shudder, is there a fix?
They claimed they did a lot of monitoring and driving but can't find anything. I think the problem is, they aren't driving it in a way that would make it happen. I believe they are driving it hard thinking its some violent shudder, no matter how many times I have explained that it is only under light load between 50 and 60 in 6th gear.
It is going back to the dealer on Tuesday next week for the tech to have another look at it.
If they can't duplicate it ask for a flight recorder. You may have to pay a deposit but will get it back when you return it. It basically monitors all the sensors all the time and when you feel the concern you press a button and it makes a recording. Then you go back to the dealer and the tech downloads the recordings and looks for anything out of whack
Well.... new TC was installed and I still have the same issue.... Its just enough to bug the hell out of me since I drive this ting 60 miles a day. I have asked for a flight recorder but the service manager says they do not have spare to loan out and none of their sister stores do either. Any more suggestions?
One last idea. Rotate the tires. BUT rotate them in a criss-cross pattern so that all four tires are now rotating in the opposite direction. I once had an SUV with a tire that had an internal belt separation. If the feeling of the shudder changes in any way you may have a bad tire. If so, have a shop try to dynamically balance the tires. That should find the bad one.
