Fairlane front end radiator mounting ideas
I am running the fairlane flip front end and need to figure out what kind of radiator to use and how to mount. I have a 302 engine btw. I was thinking of a top down aluminum with a puller fan because the opening in the fiberglass is not very wide. Any ideas would be appreciated
on
AA,
here's what we did with square tubing... stub mount to cross member and radiator slides down over them..
one thing... be sure you have adequate room between air dam and radiator when the hood closes... first try I didn't and it caused me some problems moving radiator back... with a 302 you should be fine...but with a 460 some of the room disappears..
BTW you gotta grind out the weld line in the outer tube or they wont fit...
something else you might want to look at
http://jniolon.classicpickup.com/til...gfulltilt.html
later
John
later
John
Without all the stock sheet-metal up front, a large crossflow radiator would be far more efficient than the top-down. There are generic double-pass radiators that are super efficient and should be relatively easy to adapt in the (now) large space available. Just be sure to duct it all well so all the air goes through it.
Any pics of the engine placement, and mounts
mod22
05-10-2018 04:22 PM
Onus
04-11-2010 03:03 PM
limptera13
03-19-2010 09:18 PM
