Will spare tire carrier allow a 31 inch spare?
I have a 1992 F150 4x4 and it was produced early in the 1992 model year before the factory offered 265/75 x 15 or 31 inch tall tires. My 92 was factory equipped with 235/75 x 15 tires.
Will the spare tire carrier underneath the bed allow a 31 inch tall tire? Will the bolts be long enough for the wider 31 inch tire?
The only way i have been able to fit my 265/75/R16 spare in the carrier is by airing it down to about 15-20 psi (which is way too low for me). And even then the side walls of the tire are getting pulled in so tight that the carrier is practically cutting into the tire.
Since I don't really consider this as fitting properly I suggest longer bolts, switching to a stock size spare, or do what I do and just throw it in the bed.
Number Dummy would have the definitive answer, but I thought the F-150/250/350 all used the same carrier. I know that I had no trouble fitting a 235/85-16 tire in the carrier in my '95 F-150. That's 31.7" tall but only 235 mm (9.25") wide rather than the 265mm (10.4") width the OP is asking about.
Still, from my experience the carrier will work fine with a 31" tire, but based on Fastback460's feedback longer bolts might be needed.
That may have been the problem with mine. I couldn't loosen the bolts since they were rusted in place and would not budge. So I ultimately just cut them off since the hanger was in my way when I changed my rear tank a few years ago. I had every intention of replacing them with longer bolts, but still haven't done it yet.
phoneman91
08-13-2018 07:12 PM
sgip2000
15
04-11-2015 08:43 AM
cashmoline
03-18-2005 06:09 PM
mkuze
08-22-2000 09:36 PM
