1968 F-250 Camper Special
Year: 1968
Make: Ford
Model: F-250
Price: $2250
Mileage: 35000
Color: Primer
Private or Dealer Listing: Private Listing
Location (State): CA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Gray
Engine: 390
390 V8. Holley 4bbl carb (600cfm) manual choke.
Factory Air-Conditioning. Working Factory Power Steering and Brakes.
Pertronix Electronic Ignition and Flame-Thrower coil. Interior recently refurbished.
Headlight, Horn, brake-light, turn signal and wipers work along with CB radio, Post-Mounted Spot Lights and Original AM/FM
Good Wheels and Tires. Factory Install Camping Generator.
Radio.Motor runs and Transmission shifts and stays in all gears work. However, gasket needs to be replaced.
Clean title with no back fees.
on
Have you checked the spark plugs to see if any of them our wet/fouled. Has the engine been over heated that you know of that may have caused is to cracked head or gasket to go bad?
That power pak generator is worth some bucks to the right person. Is it in working order ?
Truck look pretty straight and not abused. Nice dash an steering wheel not cracked like most.
These Fe engine once removing the intake can be a can of worms or your worse dreams if you have never done any work on one of these type of engines. Just sayin
Orich
Orich
Merlyn James
13
01-02-2018 02:03 PM
marty0108
19
08-30-2004 09:00 PM
