Gasket between up-pipe and exhaust manifold?
I have a '99 F250 Super Duty with the 5.4. I have an exhaust leak and I'm confident it's right at the joint where the up-pipe (Y pipe?) connects onto the back of the exhaust manifold. On the driver's side, for what that's worth. I could hear the air pissing out from that side of the motor and I thought (feared) it was the manifold itself either cracked or the gasket between it and the block.
But then I reached my hand in/around the back of the manifold where it bolts to the up-pipe and I could feel the air jetting out. Couldn't see any damage, however, as luck would have it the air is escaping in between the block and the exhaust.
So. I removed the two bolts/studs that hold the up-pipe to the manifold and am surprised that there is no gasket between the two. Autozone confirms that there shouldn't be. Is that right?
If not, then (unless there is a crack on the manifold that I can't see) I assume the connection just loosened up between the pipe and manifold over time and now it's leaking a little? The remedy then would be to clean both surfaces and bolt it back up?
Thanks in advance,
Jay
Thanks in advance,
Jay
Thanks man. Good point. Just looking at both now and you're right, the busted one I took out has a small hex on it - the ones I got from RockAuto has a rectangle... I'll just wrench em' in.
dmueller71
07-13-2018 11:56 AM
Mikey_23_ny1
25
05-06-2012 07:30 PM
jcbx
12-22-2008 07:45 PM
Kista20
03-02-2008 05:55 PM
