Do I just keep cranking? New HPOP and Injectors - Page 7 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page > Do I just keep cranking? New HPOP and Injectors
  #91
Old 05-10-2017, 09:01 PM
6_Myles
6_Myles is offline
6_Myles is starting off with a positive reputation.
will double check everything, but yes to all previously
  #92
Old 05-10-2017, 09:52 PM
ExPACamper
ExPACamper is offline
Almost there
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
It seems to be your HPOP...
Did you use the right gasket? The wrong one will not work properly...uhm...what HPOP are you using?
You do not have check valves in the HPOP fittings (removed them?)
I read there is a way to deadhead the HPOP and test the pressure. Maybe someone remembers the link?
  #93
Old 05-10-2017, 09:56 PM
ExPACamper
Almost there
I think the procedure is described in this thread: https://www.ford-trucks.com/forums/1...sure-test.html
  #94
Old 05-10-2017, 09:57 PM
The Brad
The Brad is offline
The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.
Pull one of the oil rail plugs and put it in one of the hpop outlets, then put a 3500 psi gauge on the other outlet and crank it over. It should immediately jump over 3000 psi. If not, it's either a loose gear, or a bad pump.
  #95
Old 05-10-2017, 10:07 PM
ExPACamper
Almost there
Did you follow these instructions when you installed the new HPOP?
What about step #17 (aligning the gear)?
See the attached PDF file.
  #96
Old 05-11-2017, 08:23 AM
6_Myles
6_Myles is offline
I did follow those instructions and torqued the shaft bolt to 95lbs.
  #97
Old 05-11-2017, 03:19 PM
ExPACamper
Almost there
How do you *know* the gears are meshed? I haven't done it yet and it doesn't seem to tell you?
Maybe it's obvious
  #98
Old 05-11-2017, 03:29 PM
6_Myles
6_Myles is offline
I assume it means that the HPOP is sitting square and flush to the resevior...there's no real 'teeth' on the shaft.
  #99
Old 05-11-2017, 03:59 PM
ExPACamper
Almost there
I've read about some times where it seemed like it was installed okay, but the teeth weren't properly meshed.
In any case, once you test the HPOP deadheaded, you'll know for certain
  #100
Old 05-11-2017, 04:43 PM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
Once you open the top of the reservoir you'll see it. When you remove the HPOP front cover plate the 95ft-lbf torqued bolt shown in Fig. 8 of the RR HPOP instruction sheet can be seen, and it holds the gear onto the HPOP input shaft. Once the bolt is removed and the HPOP is slid back out from the reservoir, the gear can be lifted straight up out through the top of the reservoir. It's driven by a gear on the camshaft(?). I don't see how it's possible that this gear can be located anywhere but in contact with the camshaft gear.
I don't remember what keeps the gear locked to the HPOP shaft, but if it's a woodruff key, maybe the new HPOP didn't have a woodruff key on it?
An HPOP rebuilder would know ...
  #101
Old 05-11-2017, 04:45 PM
jhl3's Avatar
jhl3
jhl3 is offline
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
Good old friction that is assisted by 95ft/lbs of torque on the HPOP gear/shaft bolt. Nothing more...
_
  #102
Old 05-11-2017, 06:41 PM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
There was no keyway on mine. I thought it strange for such a vital component. I seem to recall either Diesel O-rings or Riff Raff having instructions that said as long as the engine turns over, the bolt is torqued down enough. I didn't use a torque wrench on mine. I also don't quite understand how anyone would ever manage to reassemble it such that the gears weren't meshing, or weren't meshing properly.
  #103
Old 05-11-2017, 07:01 PM
JoeF250
JoeF250 is offline
JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.
In many applications where timing isn't critical, key ways have been done away with. They're not that great at transferring torque by themselves and they add unnecessarily to manufacturing cost. Plus if the joint is spun and they key is mangled or sheared it will really ruin your day.
  #104
Old 05-11-2017, 07:05 PM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
Just imagine dropping that woodruff key during assembly or disassembly.
  #105
Old 05-11-2017, 07:33 PM
ExPACamper
Almost there
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
