Do I just keep cranking? New HPOP and Injectors - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-09-2017, 09:40 PM
6_Myles 6_Myles is offline
6_Myles is starting off with a positive reputation.
Can i leave the HPX on, and just use more air/listen to both sides? I don't really have a means of blocking it off tonight
  #62
Old 05-09-2017, 09:49 PM
The Brad The Brad is offline
The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.
I think it'll push back through the hpop, but I'm not sure. Do you have a way to block one hpo line while pressurizing the other?
  #63
Old 05-09-2017, 09:59 PM
I do not...
  #64
Old 05-09-2017, 10:12 PM
The IPR is just gonna leak the air into the block. Can you connect an hpo line from 1 head to the other, then pull one of the rail plugs and apply pressure?
  #65
Old 05-09-2017, 10:20 PM
If i can get one hpo line to the other, i can pressurize through the ICP
  #66
Old 05-09-2017, 10:23 PM
But i don't think they will reach
  #67
Old 05-10-2017, 12:37 AM
JoeF250 JoeF250 is offline
JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.JoeF250 has a good reputation on FTE.
64% IPR is fully closed. But the reading doesn't mean that it's actually fully closed, rather that the truck is commanding it fully closed. Doesn't mean it's actually getting there. Double check that it's installed correctly and functioning. I'd have tried the old one before I would have started some of the other tests. As the previous poster mentioned it's possible to install it so that it can't fully close.
As to lubing up the orings. Lightly oiled, may not be enough. When I did my orings I dipped them all before installing on the injectors and then dipped four full fingers in the oil and slathered it on the injectors like I was putting sun screen on a sexy redhead.
Any time your ramming a cylinder into a tight hole you can't have too much lubrication.
  #68
Old 05-10-2017, 06:44 AM
Lolol, i dig your style Joe.
I just felt like the chances of a bad o-ring are much higher than a bad, brand new oem ipr. I also thought i could just take off my hpx and do the air test, which was easy too. Swapping ipr's out later today
  #69
Old 05-10-2017, 08:42 AM
Tugly's Avatar
Tugly Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by The Brad View Post
As long as it's not #5 or 7. Good luck!
Aw.... it ain't that bad. Of course, I said the same thing the first few times of popping those bass turds out.
Quote:
Originally Posted by 6_Myles View Post
so i'm gonna ask two maybe dumb questions:
1. does it matter which hpop line goes to which head?
2. I just tried to perform the Cody test by pulling my oil high pressure crossover and feeding down the driverside head....i was immediately sprayed with oil from the passenger side head.....is this normal?
1. It matters only in terms of which one reaches where.
2. You have a new HPOP, and it sounds to me like the check valves are not in there - or the oil would have stayed in the system. Since you are rid of the check valves in the HPOP, might I suggest you completely and permanently do away with the HPX. Removing the check valves performs the same function as the HPX, so removing the HPX simplifies the HPO system.
  #70
Old 05-10-2017, 09:16 AM
ExPACamper ExPACamper is offline
Almost there
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Quote:
I'm making this same change this week/weekend.
  #71
Old 05-10-2017, 09:18 AM
Good to know...i will do that. Anyone happen to know the thread/o-ring size of the plugs?
  #72
Old 05-10-2017, 09:44 AM
I know it doesn't tell you the size. But I'm pretty sure these are the droids you're looking for. You could probably call Clay and ask, if you're​ in a hurry and need to find them locally.
High Pressure Oil Rail Exterior Plug - Riffraff Diesel Performance
  #73
Old 05-10-2017, 09:48 AM
Thanks Joe! Local stealership has 4 instock. this will make the cody test waaayyyy easier.
  #74
Old 05-10-2017, 01:30 PM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Taking the HPX off will noty cure your problem. I still have mine on with the T50 witch doesn't have check valves. But doing the Cody test will let you know if the 0-rings are leaking. At this point, I say IPR or loose nut on HPOP. I'd do the IPR first. Then Cody test, if okay check the nut. If you built up over 2K psi with the IPR discounted it should of started. Do you have the wait to start light on?
  #75
Old 05-10-2017, 03:06 PM
I believe they're either #4 or #6 ORB. You'd probably save money at a hose shop.
I think i just scored HD wheels! 6_Myles Excursion - King of SUVs 25 10-29-2017 07:50 AM
P1273 Code - Ran all the normal tests 6_Myles 1999 - 2003 7.3L Power Stroke Diesel 16 09-28-2017 08:59 AM
ISO 3rd Row Middle Seatbelt 6_Myles Excursion - King of SUVs 0 04-23-2017 08:46 PM
ICP slow to 500 on cranking Icicle 1999 - 2003 7.3L Power Stroke Diesel 6 02-20-2016 01:37 AM
Fuel Sending Unit - Random Thought 6_Myles Excursion - King of SUVs 1 02-16-2016 09:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
