Do I just keep cranking? New HPOP and Injectors
#47
As I remember (which is poor) there is a sensor (might be a coil inside) that slides over the IPR "rod" which sticks out from the pump. Behind the sensor was a brass looking spacer and then the tinnerman nut. I had the spacer first, and the sensor behind.
#48
That "sensor" is an electromagnetic solenoid, which controls the inner workings of the IPR. By putting it at the end, it's kinda like getting ready for a field goal, but instead of setting up at the 30 yard line, you're stuck waay back behind the 50. No field goal tonight!
So guys, how shall we name this "mod"?
#49
#50
on
Next, did you replace the new IPR with the old IPR and try to crank?
Those two steps are the easiest and will give us some valuable info and it will only take 5 mins to do both and report back.
#55
This says your ICP sensor works, and the HPOP pressure reading is accurate. When my IPR starting sticking, my no start crank had IPR going from 65 - 98% and ICP staying around 200-250psi.
#56
#57
on
I thought the 2147 psi was with the ICP sensor unplugged which would be default PCM ICP for that duty cycle????
Anywho, I would try swapping out the IPR next, and then as Brad said, make sure the bolt for the HPOP drive gear is torqued properly: 95 ft/lbs. If it is loose, it can cause low ICP. You can use a breaker bar and a block of wood on the crank shaft to prevent the engine from turning.
Do you have any raw diesel/white smoke being expelled out of the exhaust?
#58
so i'm gonna ask two maybe dumb questions:
1. does it matter which hpop line goes to which head?
2. I just tried to perform the Cody test by pulling my oil high pressure crossover and feeding down the driverside head....i was immediately sprayed with oil from the passenger side head.....is this normal?
#60
