Do I just keep cranking? New HPOP and Injectors - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 05-09-2017, 09:49 AM
6_Myles
6_Myles is offline
6_Myles is starting off with a positive reputation.
not. even. trying.
that's why i'm thinking it is still air locked, or some other 'simple' issue.
  #32
Old 05-09-2017, 09:53 AM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Originally Posted by 6_Myles View Post
not. even. trying.
RPM, ICP, Fuel delivery (firing). That's all.
It should at least stumble if there is a problem with programming for injectors, a bad injector install, etc.
Does your tailpipe smell like diesel fuel? Any smoke while you crank?
  #33
Old 05-09-2017, 10:11 AM
SaintITC
SaintITC is offline
SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.SaintITC has a great reputation on FTE.
Is the 42pin connector tight? Don't ask me why I'm throwing this out there..
  #34
Old 05-09-2017, 10:15 AM
6_Myles
6_Myles is offline
lol. I'm open to all suggestions at this point
  #35
Old 05-09-2017, 10:20 AM
ExPACamper
Where are you located? Maybe someone nearby has AE and can help monitor some of the numbers while cranking?
  #36
Old 05-09-2017, 10:28 AM
6_Myles
6_Myles is offline
I have AE, that's how I know IC pressure/duty cycle.
  #37
Old 05-09-2017, 11:57 AM
ExPACamper
Ah...good.
Can you give us a rundown then while cranking in AE:
RPM
ICP
Battery Voltage
FIPW
ICP DC%
I *believe* (but haven't confirmed) that if FIPW is Zero, the injectors aren't firing. I don't know another PID to check it?
If the top 3 are in the Green (values, not in AE), then you should have FIPW.
I also think that if FIPW is showing, but no fire or fuel out the tailpipe, then you have a fueling issue (filters, pickup lines, fuel rail lines, etc)
Did you reply about any smell in the tailpipe or smoke and what color?
(I was out prepping the garage, moving stuff around for this week's project work)
  #38
Old 05-09-2017, 12:05 PM
6_Myles
6_Myles is offline
I will check on all those in a few and let you know. Haven't been home yet.
  #39
Old 05-09-2017, 12:08 PM
Bonanza35
Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Everything I've read here still only shows 270 ICP. Has to be 500. Keep cranking or start testing HP system.
  #40
Old 05-09-2017, 12:15 PM
ExPACamper
You're probably right. I was looking to be definitive on the RPMs, too, so we are looking at only one system holding him back
I may be in the garage when you're back on, heading back there right after some lunch.
  #41
Old 05-09-2017, 01:06 PM
6_Myles
6_Myles is offline
Let's assume this is an o-ring issue...what's the likelyhood that i can pop the valve cover and see which one is blown out by cranking it?
  #42
Old 05-09-2017, 01:42 PM
cjgray1974
cjgray1974 is offline
cjgray1974 is gaining momentum as a positive member of FTE.
The Cody test is the easiest way to check for a bad injector o-ring. If you have an oil rail crossover, remove it, if not just pull a oil rail plug and use a air nozzle with a rubber tip wrap a rag around it and put pressure into the oil rail and hold it for a minute or two. listen for gurgling. If you don't hear any go to the other side.
Wrap the nozzle with a rag or when you remove the nozzle from the hole you will get covered in oil.
I had a no start about 6 months after installing new injectors, only building 250 psi, and that is what it ended up being.
  #43
Old 05-09-2017, 01:54 PM
GEugeneS
GEugeneS is offline
GEugeneS is starting off with a positive reputation.
I put the IPR sensor ln backwards after repairing the IPOP. Kinda stupid but the result is it wouldn't fire at all. Put back on correctly and it fired right up.
  #44
Old 05-09-2017, 04:18 PM
Tugly's Avatar
Tugly
Tugly is offline
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Originally Posted by GEugeneS View Post
I put the IPR sensor ln backwards after repairing the IPOP....
You mean the coil or the needle valve? In my head, I'm seeing a tinnerman nut being jammed into the IPR hole on the HPOP... and that can't be right.
Oh crap..... Doesn't the IPR and the EBPV have the same connector?
  #45
Old 05-09-2017, 04:31 PM
andym's Avatar
andym
andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
They do, but the wires aren't long enough to reach the other connector.
Quick Reply: Do I just keep cranking? New HPOP and Injectors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
