electrical gremlin/engine shut off
Old May 7, 2017 | 09:21 PM
scottb37's Avatar
scottb37
Hey Yall, riding along in my automobile...... Er, leaving the food store and heading for the house, went about 5 miles and she shut off (99 Expy EB 5.4 4r100 4x4 with no 4HI and new Bosch fuel pump).
Tried to start, either no fuel or no spark. Fiddle with some fuses and the inertia switch but it was dark enough and noisy enough that I couldn't hear or see much. After about 10 minutes it fired up and drove it to my shop to get my other car.
Got it in the shop, shut it off, and tried to restart it. No dice. I noticed that the gauges were not working and the odometer just showed dashes. I unhooked the battery and had to leave as 3:30 am comes awfully early. Right now I am leaning towards bad battery of bad bad battery connection.
In my mind it sounds like something is getting heat soaked and failing, then working again when it cools off. Has anyone been down this path before and can offer some tips and tricks?
Thanks, Scott
Old May 8, 2017 | 09:27 AM
alloro's Avatar
alloro
All dashes on the odometer could also mean a loss of communication with the ECM. That along with the stalling could be pointing to a failing ECM.
Old May 9, 2017 | 03:21 AM
scottb37's Avatar
scottb37
Found it, bad PCM power relay. It would get hot and fail then cool off and work again. Swapped it with another and all is good. Thanks, Scott
kevrobinson78
2004 - 2008 F150
Feb 15, 2012 07:00 PM
01f150supecrew
1997 - 2003 F150
17
Dec 17, 2010 10:43 AM
jbailey888
Aug 20, 2007 02:36 PM
hagg26
Sep 16, 2005 05:25 AM
Snowman4x4
Electrical Systems/Wiring
Aug 20, 2002 08:50 PM
