Seatbelt repair ideas?
#31
Perhaps so. I saw the video below about how to fix the spring tension on an older car.
I went out to see the ones in my truck and they are similar in that they are seat belts, but the spring is either internal to the mechanism somehow or under a black cover on one side. The other side I can see the ratcheting and stop gears, but no spring. I may just take the mechanism out of the truck and see what I can see about fixing them.
The soaking in water for 24 hours did nothing in the way of recoiling the belt.
#32
#33
#34
Now on the hunt for a new repair shop...
#37
#39
I will wait until I hear back from Mike before looking into the other places noted above.
Thanks for the links though, this is a team effort.
#41
This problem is inherent to all Ford Trucks until 2003 (whenever the interiors received a facelift, whatever year that was).
You could retrieve a set from a Salvage Yard from an 03 or later and hope for the best. Same mounting as I recall. Although I am uncertain of the Belt Length itself.
Haven't come up with any resolutions that aren't new (I found the same price that Sous did). Yes safety is important but $1200 is not in the cards right now (I've got a substantial oil leak that requires the buck$zooka) when they still work (just don't retract worth a darn).
Suprisingly there are not may Superdutys or Excursions in the local pick-n-pulls. Even then that stuff is pretty well picked through early for those types of items. I keep checking occasionally on CL for a set but nothing. Either I'll end up coming across them or my wife will have had enough and authorize the purchase.
#42
#43
Hope you guys don't mind if I jump in on this thread as mine are acting up as well. I found another possibility for seatbelt repairs. This outfitt is in New York. Link below. SRS Module..
SRS Airbag Module Reset & Seat Belt Repair Services
#45
I'm not saying they don't do good work as I personally have never used them. I just thought this to be an interesting read is all.
We have all had a bad experiences with a vendor at some point in our lives, but most of the time people want to try to do the right thing and make it right.
Ripoff Report | Safety Restore TRUSTED BUSINESS | Ripoff Report Verified? ?businesses you can trust. Safety Restore the world's leader in post-accident restorations specializing in seat belt repairs and airbag modules. Safety Restore has the largest
