2006 superduty AUX button radio swap
My 06 Superduty had a plain jane AM/FM stereo. I got a 6CD MP3 replacement from a pick-a-part. I don't know the vehicle it came from, all I can say is that it was an SUV. The radio didn't look the greatest, but it worked. I went back to the junkyard to see if I could get the plug for the AUX line-in. I found a 2007 Fusion that had it so I grabbed the radio, cut the plug that goes into the back and grabbed that too. The line-in was in the center console so I cut that out too. There were seven wires coming out of the radio plug and four coming out of the line-in jack. I connected the four wires because they were the same color on both ends. One was a black wire that ran to a foil shield that encased part of the harness. I guess the other two go to the CAN bus? I don't know, there is no provision for them in my truck. The fusion radio takes a different antennae plug and the face doesn't work. When I plug in the line-in plug that I wired up, it only works on one channel. When I plug it into the radio from the SUV and hit the AUX button, it says NO AUX. Do I need one of those PIE connectors, or is there a way to make my pigtail work?
spinner605
03-02-2017 12:38 PM
seuadr
1999 to 2016 Super Duty
12-06-2013 05:16 PM
John with beastly 302
04-17-2008 12:22 AM
