95 f350 7.3 has zero power and getting worse HELP
i have a 95 7.3 manual
the problem started maybe a month ago and has gotten increasingly worse
from a stop after running and at a light i can hit the pedal over and over and get nothing pop the engine forward in 1st gear and i get throttle......empty or loaded if i hit any kind of up grade hill it just slowly just loses power and cant get out of its own way have to wait till it stops after down shifting the slowly and i mean slowly crawl in first and if im lucky second gear it simply has zero power its running but just dies but still runs but today stopping and going i have to shut the truck off restart just to get power to have the throttle work im at a loss its throwing zero codes with a snapon reader reads everything on the truck so yeah need help as i can keep driving with zero power flat surfaces if im moving it goes hit a hill and it just dies down hope this is enough infor to get some pointers
First, since this is NOT chat, and people will be referencing this information FOREVER, is it too much to communicate in sentences?
Next - does the accelerator respond while standing still?
Third - if your Snap-On device can read live data - can you set it to read accelerator position (pref. as a %) and idle validation switch state?
sometimes it does.....if i restart the truck it will respond
but for the past week without jumping it into first gear no i will get nothing from the pedal...
and when i drive any strain on the motor i.e up a hill it just dies down and has nothing......until i start in first and wind out the gears
update......
checked fuel in front tank was horrible stuff looked like milk alot of water ..........water in fuel light cam on today so pulled open tank screen on pickup tube was off drained tank got years of crap and i mean crap out of tank squeeky clean reassembled truck runs a ton better but still issue no pedal only if i turn truck on and and have pedel pressed will it throttle let off and back to no pedal cant even pop first to get throttle........went and got tps still same result accept with the new one press pedal and check engine comes on (aftermarket part) not oem .....but requardless no pedal at all unless truck is turned off and back on then i have pedal until i let off of it........soon to be truck for sale...
