Bolts and hardware (trasfer case mount bolts)
Anybody know where to get transfer case mount bolts for a 66 f-250 4x4? Is there a good place that will sell a lot of the bolts and hardware for my truck? I can find the rubber bushings for the transfer case just about anywhere. Only problem is the only way I'll be able to replace them is cut the bolts. They arent regular bolts, they have castle nuts on top.
Castle nut (34034-S); flat washer; round donut shaped rubber insulator (B9TT-6039-A); metal plate; square rubber insulator (B4Q-7010-B);
Stud-Transfer Case to Support / 5/8" -11 & 9/16" -18 x 3 1/2" long = C0TT-7A053-A / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
FEYER FORD in Edenton NC has 4 = 252-482-2144.
You will need the studs, possibly the castle nuts.
Thanks for the reply. You are right, I got mixed up. There are studs at the top with castle nuts on them. After looking at it a bit I think the best thing I can do is cut the bolts off the cross member the transfer case bolts to. They are standard bolts I can get anywhere. Then I can lower the transfer case down with a jack and have better access to get the castle nuts off the studs. It sounds like a plan. I hope it works!
queen of spades
1999 to 2016 Super Duty
13
02-13-2018 08:14 PM
myklstrng
11-14-2010 10:42 PM
