Does anyone use Torklift's StableLoad Suspension Stabilizers?
Does anyone use Torklift's StableLoad Suspension Stabilizers? I pull a travel traliler that weighs almost 9000#'s and it makes the back end of my truck squat. I was thinking about putting air bags in, but ran across an add for Torklift's StableLoad Suspension Stabilizers, and checked out their website.
Better option or not?
I have a 2016 F250 Crew Cab SLT 4x4 gas.
My plan was to add airbags if the Stableloads didn't do the job. They worked very well and I didn't see the need for using airbags. Stableloads are as close to a trouble free solution for the load you have as can find. I spray them liberally with Fluid Film and they withstand the winter road salt like new.
No more squat when the Stableloads are engaged. They don't raise the bed, only resist the loading by preengaging the helpers. Simple and effective.
I did extensive research (almost 2 years ... I was in no hurry for the wrong solution) on what modifications would best serve my needs. I do not have StableLoads but I did consider them. The main reason I rejected them is they do not add any additional weight carrying capacity. They simply engaged the suspension sooner and thus, they seem to do a good just with sag and somewhat with sway.
My research helped me decide on installing Sumo Springs. Why? The Sumo Springs I bought (Solo model I believe) added 2,800 lbs. more carrying capacity (not legally of course but practically), they only engage when I have a heavier load (when I'm light loaded they don't assist at all so the ride remains "normal"), they helped stabilize our truck's sway and porpoising when heavy loaded, and ... they reduced my sag from 3.5 inches to just over 1". They were the right solution for me and I couldn't be happier. Click on Rear Sumo Springs in my signature for my write up ... Post # 29 is my summary.
