Wiring 51 F4
Old 05-03-2017, 10:10 PM
Berthoud51's Avatar
Berthoud51
Berthoud51 is offline
Originally Posted by ALBUQ F-1
I realized DW was correct, my first diagram above was backwards, for the parking lights (front) and taillights (rear). I corrected it above.
Do the front parking lights go out when the headlights are on?
In your initial post you said the PL's are on regardless of ignition switch position; note that the light switch is not fed thru the ignition switch.
Ross,
Yes.
Update: I just finished updating the front pl wires with the correct wires, and now two things happen:
- rear lamp is still on continuously
- front pl are on when switch is in off position, and yes they go out when headlights are on.
I was under the impression the pl were supposed to go out when the hl are switched on.
Old 05-03-2017, 10:15 PM
Berthoud51's Avatar
Berthoud51
Originally Posted by Jolly Roger Joe
It sure sounds like there's an internal short in the light switch between the post for power from the CB and the post for the rear lamps.
This is going to sound crazy, but try pulling on and pushing off the lights several times quickly. If there's something internally shorting the two contacts, maybe that will break it loose.
But, if you can get to it with a meter, just check for continuity between the two posts with power removed.
Could be Joe.
I am going to Pick up a meter with continuity function this weekend to see if there is a continuity issues. I am also thinking that I need to remove and give a solid cleaning with q-tip and isopropyl. Maybe I can clean it off well enough to fix the issue.
Maybe not.
The town parade is coming up in early June. Hope to have it nailed down in time to roll through the hamlet in the slow lane.
Old 05-03-2017, 10:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Originally Posted by Berthoud51
Ross,
Yes.
Front PL's are not on when the headlights are on, on a stock switch.
It almost sounds like your switch isn't going in all the way to "off".
Old 05-04-2017, 09:29 AM
Berthoud51's Avatar
Berthoud51
Update:
Removed and cleaned the switch. Reinstalled, and the problem persisted. I removed the switch altogether to see if the switch had anything to do with the problem. Short answer, no. So I am now looking at the CBK or the break switch, as these are the two remaining potential sources.
Am I correct regarding the cbk being an all or none item (can't replace the individual components)?
But then again, the Rear pl has nothing to do with the cbk. The diagram basically has the 13B wire to rear pl going from the switch to the lamp. Hmmm...
Old 05-04-2017, 10:00 AM
Berthoud51's Avatar
Berthoud51
Solved! Lowest common denominator.
In short, it was a faulty double splice wire connector. The first connection downstream from the firewall, where the body harness ties into the dash harness.
Swapped it out with two individual splice connectors, and there it was.
Thanks again for entertaining the topic!
New POS splice
The solution.
Old 05-04-2017, 02:11 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Glad you found it. Removing the switch and still having the problem meant it had to be a short somewhere.
Good job!
Old 05-04-2017, 08:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I suspect that isn't a double splice but a 4-way splice, all 4 corners connected. Useful for connecting grounds.
Old 05-04-2017, 10:01 PM
Berthoud51's Avatar
Berthoud51
In hind sight, I would have to agree. Chalk it up to a rookie error.
It was nice to get it fixed and move on to the next stage.
Thanks again Ross!
Old 05-05-2017, 10:57 AM
Jolly Roger Joe
Yeah, I think that's what Ford used on our dome lamp wiring for the door switches... but maybe I should just go away again. I usually don't know what I'm talking about.
Old 05-05-2017, 01:28 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
Yes you do Joe!
And good to see you. Thanks for the visit! How's you 65 doing? and how is your son making out with your old flatbed?
ungerp
07-08-2014 09:57 PM
JT250
36
03-02-2011 06:33 PM
jccraig
19
12-09-2010 12:53 AM
broncobillyII86
Bronco II
01-05-2007 02:00 AM
jm72
05-11-2006 08:17 PM
Quick Reply: Wiring 51 F4
