May 2017 all topic thread
#47
Moderate heat here. Guess we are close enough to the coast to enjoy the light sea breeze. Happy about that.
BTW - cooked bacon (BACON!) for breakfast today. Picked up a couple pounds of the applewood smoked bacon at Costco last week. I've found that the BEST WAY to cook bacon is on our BBQ. It's a little tricky, but I have the formula down, and it is hands down the best way to cook the stuff.
#48
#49
#50
Well, after checking the weather report (I knew I shouldn't have) I find out that for the next five days it will be high 90s to low 100's and the two days over a hundred? Sunday and Monday. Except for church, looks like I will be a man-cave dweller for he next few days. Glad Winco is open 24/7. Can go grocery shopping early in AM or late at night when it is not that hot.
Totally missed the cooking bacon on a BBQ part. Never tried that, should be fun, except i don't have a BBQ.
Jim
Jim
#51
#52
#55
The secret is using a good propane grill with a mezzanine. We have a Weber with a mezzanine that is ~~ 8" above the main grill. Start at medium-low temp (keep it below 400 degrees). I then close the lid, and keep it shut for between 3 and 4 minutes. If a lot of smoke starts coming out, you are getting a flair; open the lid. The flairs will be below the less-lean parts of the bacon. Lower the grill temperature to control the flair ups. By the time the bacon is near the end, I generally have the grill on the lowest temp setting; sometimes I even turn off one of the burners. It is actually more baked than grilled; I like it because the clean up is so, so easy (like none).
#56
Thanks again for the smilies Stewart!
#58
I will say that after I read about it, my first attempt was on the main grill. I managed to basically vaporize the bacon. You have to keep an eye on it, and you have to turn it every 3-4 minutes. Total time from start to finish is usually about 12 - 14 minutes.
#59
I broke in my smoker with a slab of back fat, greezed it up real nice , the only thing to do now is change out my smoke box to a bigger tank , had a hard time keeping the heat with it but had plenty of smoke.its a home made smoker out of a water heater and 5 gal propane heat box .
As for the heat wave, not liking it , when's it going to cool off and rain
