1977 F600 361 wiring problem
I bought a "ran when parked" and I am trying to put it back together. The distributor cap was off and no points in it. I put a Pertonix with a coil back in. New starter solenoid. Engine turns over but doesn't try to start, but when I arc it from the solenoid it is trying. Question is, what is the ignition wiring diagram. Everything I find shows an ignition module?? There was also a red and blue wire from the firewall that wasn't connected to anything. What wire goes on the coil other then the pertonix red and black??
Thanks
Thanks
No 1974/78 500 and larger series truck with an FT engine has a module.
Some 1974/75 Passenger Cars; F100/350, Bronco & Econoline. ALL of these after 1975.
Some 1975 F500/600 with 300 I-6; Some 1976/79 trucks with 300 I-6 & 401/477/534 (gas V8's); Some 1979 trucks with 370/429 (gas V8's).
ALL 1980 and later trucks.
DuraSpark electronic ignition:
Module factory installed on the left fender inner apron, just in front of the firewall, but your 1977 F600 w/361 FT engine didn't come with it originally.
So a wiring diagram will not show the module unless the truck has a 300 I-6 or 401/477/534 V8. 370/429 not available until 1979.
Ok, I said resistor but I meant the condenser in the distributor is removed. The pink (looks red to me) is the resistor? I did try a hot wire from the battery to the + of the coil and still nothing. My test light flashes from my coil wire to the distributor but I only get maybe one flash on my plug wires.
