35x11 tire on 22x10 wheel with -20 offset DOES IT RUB
I have a 2017 f250 lariat and i want the biggest tire/wheel on stock suspension with the littlest amount of trimming?35x11 tire on 22x10 with -20 offset DOES IT RUB on stock suspension. Also what is other tire wheel combo on stock suspension with min to no trimming
I think you will be very close. The plastic drain channel at the rear of the wheel well may need to be trimmed off, and the front bumper will be iffy....
I just did a 1.5 level, 35x12.5 toyos on 20x9 Badlands with -12 offset. I didn't do the track bar relocate yet and the axle is 1/2" off to the left, so it pokes out just about how far you will, I think. I clear. the plastic drain channel at the rear of the wheel well is within 1/4" and the front bumper is about 1" clearance. That is sitting level, I haven't bound it up yet to see if I have other issues...... Good luck.
Leovardo
2017+ Super Duty
04-30-2017 08:28 AM
DDRanger
11-12-2010 04:11 PM
97stroker-kt
05-26-2008 10:06 PM
