Cruise control swap?????
Old 04-30-2017, 07:35 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
I posted this in the Powerstroke section but haven't received a response......Ive got a 96 Powerstroke 5 speed with no cruise......I just picked up a 95 Power stroke 5 speed with cruise.......I would like to put the cruise off of the 95 on the 96..........Anyone done it?????? What am I getting into???
Old 04-30-2017, 09:29 AM
Benztechnc's Avatar
Benztechnc
Benztechnc is offline
At the top of the forum there is a sticky, read first, tech thread that addresses cruise control, and adding it. It mainly applies to gas engines but I would think some of the Items listed would also apply to a diesel set up.
that would be where to start.
Old 04-30-2017, 10:12 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Yup.......already looked at that........was just hoping for a bit more info......
Old 04-30-2017, 12:44 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Speed Control on Powerstroke trucks is controlled by the PCM. There is no Speed Control servo like gas engine trucks use.
The buttons on the steering wheel go directly to the PCM.
Old 05-04-2017, 08:44 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Yes I realize that the cruise runs thru the PCM......but are all PCM's cruise compatible???
Old 05-04-2017, 09:45 AM
rla2005's Avatar
rla2005
As far as I know, yes.
Old 05-04-2017, 12:23 PM
madpogue's Avatar
madpogue
madpogue is offline
If you're dedicated to getting cruise, the first step is to get the wheel and column (IIRC, you were going to swap columns, right?) installed. Then just try it. If it doesn't work, you might have to try a different PCM, or find someone who can flash your PCM to enable cruise.
Do you have AE or any other device/software that can communicate with the PCM?
jeff69z28
1999 to 2016 Super Duty
05-07-2019 11:52 AM
RubyRed 4.30s
2017+ Super Duty
10-07-2018 09:14 AM
78 PEB
05-04-2017 02:08 PM
murphylaw80
03-31-2009 09:11 AM
dusty1
2004 - 2008 F150
15
03-11-2004 04:54 AM
Quick Reply: Cruise control swap?????
