Trailer Battery Corrosion
#31
#32
The theory with the dielectric grease is that the current goes through the metal-to-metal connection, and the grease fills the rest of the void space, not allowing any liquid or gasses to enter and corrode.
I use it in this application, and haven't had an issues. I think the fact that you are screwing together two soft metals helps here.
#33
Nope, I don't want conductive grease. I want non conductive to help prevent corrosion. You'll find that smearing dielectric grease on doesn't affect the current as long as you get a solid and tight connection. And it completely prevents corrosion in what I've seen.
76supercab2
Electrical Systems/Wiring
04-20-2004 11:50 AM
