Do touch up kit color mixes vary by year
I'm going to get a touch up kit for my Ruby Red F150. I seen them listed from different sources identified by year i.e. RR 2014, RR 2015, etc. Is there a difference. I've had to have my 2015 RR repainted recently and they may have used 2017 mix paint but I'm not sure without asking them.
Also, who are the best resources for touch up kits. I haven't had good luck buying Ford's pens as far as matching.
Thanks.
Thanks.
If your bodyshop is using waterborne paint they will not be able to provide touch up for you to take with. Waterborne in touch up has to be activated and used right away.They might be able to do it for you. I do it all of the time at my shop. Aftermarket touchup paint is solvent. When painting a car there are several color variants to choose from based on field formulas and origin of factory. Touchup paints in general are just what is considered a prime formula. It won't vary enough to be really noticeable if all you are doing is touchup. Keep in mind code RR is a applied in a 3 stage tinted clear coat process. Matching it in touchup form is practically impossible. Let's hope whatever you are touching up is very small. You can get really good touchup paint online at "paintscratch.com"
Good luck.
Good luck.
Thanks.
Thanks.
dagwood387
16
04-17-2010 09:27 PM
