Freeze Plug Above Starter
I need to replace the freeze plug that is above the starter and have heard that a standard cup style plug will work for this hole. Is this true for the 6.9? I'd rather not buy the special tool for a single freeze plug and I know how to set the cup style plugs.
Thanks
Thanks
If you're talking about the block heater location then that won't fit the special IDI freeze plugs. Why not just put a block heater back in?
In any event, I used a rubber expansion plug (1.5" maybe?) when my block heater failed, until I got a replacement. I don't see why a regular freeze plug wouldn't work.
Around here they block the passes when it gets that cold. Our cold nights at 20 degrees here so it should be good. If not then I'll be draining coolant and adding a block heater in December.
Ambulancewarrior
04-30-2019 07:23 PM
beerman2therescue
01-28-2008 10:38 AM
