Hi I'm new to the site. I have a 1996 crew cab 4x4 f250 7.3 with 299,000 miles with and intermittent brake warning light. I've checked all vacuum lines and vacuum pump all seem to be in good working order, brake reservoir is full. Not sure where else to look, any help would be greatly appreciated.
I think It should pull 19-22 in on a gauge. I put a new one on and it only lasted a mo.. Does your brake ease down while setting at a stop? How old is the booster?
I think the parking brake light can come on with a bump, that happened to me before. I'd check that switch. I had the switch at the reservoir go bad before i didnt get a brake light but it would intermittently shut off my cruise controler and i also had the switch go bad at the pedal which would cause the same issue. The only one that caused a light was the parking brake switch.
