1970 f250 4x4 brake booster help
The 54-73112 dual diaphragm booster/brackets is what I have in my truck. The input rod on this booster (between the brake pedal to the back of the booster) is not adjustable in length.
The 54-73112 number is sort of a generic number that spans across the Bumpside and Dentside F350 dual diaphragm boosters. IF you use this booster, see if you can get one specific to a '68-'72 F350. It will come with an adjustable input rod.
F350 dual diaphragm booster with the adjustable inout rod I installed in my friend's '72 F100 Sport Custom. The input rod code on it is FT8.
From the 1969 Ford Truck Shop Manual.
The '75 F350 dual diaphragm booster I have in my truck does not have the adjustable input rod.
on
I pick up the booster from a 70 pick up with the M/C and took it whole unit to a loco rebuilder.
I have found out over the yrs that many M/C have different inner depth stroke.
If you get one with a shorter stroke M/C then the pedal won't go all the way to the floor causing the M/C to bottom out about 2/3 from the floor board= sheet metal.
Also the booster, I am using just fits with little clearance from the valve cover, but not using the oem valve covers but the tall Aluminum finned ones about 1"between the two.
I know the later larger 73 & 79 would have a mounting issues unless the whole later pedal set was used that sets the booster higher on the fire wall.
Orich
Orich
Orich's booster is the single diaphragm, non-bellcrank booster that would have been optionally available on the '68-'72 F100s or on the '68-'72 F250s with 4-wheel drums.
The dual diaphragm, non-bellcrank boosters were optionally available on the '68-'72 F350s with the optional front discs.
In '73, single diaphragm, non-bellcrank as well as bellcrank boosters were available. The bellcrank style mounting brackets lifted the booster up nearly 3" higher than where the non-bellcrank booster would be situated.
Non-bellcrank bracket assembly on a dual diaphragm booster. (booster assembly from a '74 F350).
Single diaphragm booster on a non-bellcrank bracket. (booster from a '68 F250 with 4-wheel drums).
11" dia. single diaphragm booster on a bellcrank bracket assembly. (this setup from a '78 F150). Notice it has a 'flat' input rod to the bellcrank assembly. The flat input rod on this booster is longer than the one used on this same style booster from '73-'77. You would have to modify (shorten) the '78/'79 input rod to line up with the brake pedal on a '68-'72 model truck.
Beginning in '77, the trucks with a 460 had dual diaphragm boosters mounted to this same style bellcrank bracket assembly. This would raise the booster up high enough to clear a big Ford engine with tall valve covers.
BigB9000
45
01-19-2022 04:00 PM
1977 crew
29
09-29-2007 09:42 PM
