Tire size alternatives to 285/75R16s
Old 04-26-2017, 10:32 AM
CaptCrazy's Avatar
CaptCrazy
CaptCrazy is offline
Time to give the old gal some new shoes.
Currently sporting an OLD set of 265/75R16s that need to go. Will be doing spring replacement/upgrades soon but maybe not before tires need to be changed. Springs may happen at the same time however. Especially if they HAVE to.
Was thinking of going up 'a little' (nothing too much).
Seems like most people have 285/75R16s to help cushion the stiffer springs and account for the lift. Downside was that I read somewhere they aren't the best fit for the stock rims (don't remember why).
Was wondering what other options there were.
I have been told 255/85R16s were a better fit for the OEM rims.
V10 w/ 3.73 gears
I have even seen at least one reference to 295/70R18s but know nothing about them.
Pics would be appreciated.
Old 04-26-2017, 11:03 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
My F350 (plow truck) wears LT235-85r16
They are a bit thinner but overall seem about the same height.
Old 04-26-2017, 11:50 AM
IMASAP's Avatar
IMASAP
IMASAP is offline
If you want something a little bigger than stock, go with the 285s. They are a little wider, but there are 10s of thousands of guys running them on stock wheels with no issues.
I like the 255 / 85s ..... I looked at them pretty hard for my F350 a few years ago. My issue with them was that no tire shop within 500 miles of me stocked a single one. If you go with them, make sure you do your spare too. If you ever need to replace a tire out on the road somewhere, you'll be sitting until you can order one online and get it shipped to you. Today, that is only 2 days, but still.
Old 04-26-2017, 11:53 AM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
295/70-18 Cooper ST-Maxx on oem 05+ wheels
Old 04-26-2017, 12:20 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Vinny G-the EX man is offline
I have 285/75 16 on mine with no issues. Actually my spedo was more accurate and I picked up about 1 mpg with them. Remember to purchase them at a tire shop because the big box stores will not mount anything but stock size. Good Luck
Old 04-26-2017, 01:07 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
33x12.5x16
Old 04-26-2017, 01:43 PM
CaptCrazy's Avatar
CaptCrazy
Looks good and meaty. Are you on stock springs or is that with/after a spring upgrade?
Old 04-26-2017, 06:07 PM
gots_a_sol's Avatar
gots_a_sol
Well...
I have the complete 05+ coil suspension under the front, which IS on stock coil springs
Rears are stock super duty with the overloads removed (not sure on spring rate, from the same truck that donated the coil suspension). I wrote down the before/after measurements somewhere, but it is somewhere around 2-3" taller than the oem Ex springs.
Old 04-26-2017, 07:20 PM
Diverdom's Avatar
Diverdom
Diverdom is offline
285/75/16 bfgoodrich all terrain ta2
Old 04-26-2017, 09:15 PM
lovestrucks's Avatar
lovestrucks
lovestrucks is offline
Toyo MT's (285/75R16) on stock rims, no issue.
......but I just got these last weekend.
Raceline 935BZ (Bronze) Defenders (17x9)
Toyo AT II's 35x12.5R17
Some light rubbing on the front wheel well's (that foamy stuff, no hard plastic). I probably wouldn't have as much rubbing but I recently passed 140K miles a few weeks ago and my leafs are sagging bad. I've planned to get some custom leaf's with a 2" lift.
Old 04-27-2017, 05:06 AM
rundm's Avatar
rundm
rundm is offline
Those gold rims look good on your EX.
Old 04-27-2017, 09:21 AM
ithaca1230's Avatar
ithaca1230
ithaca1230 is offline
I run 285 75 R16 on mine (Modded V's modded B's) and no problem on stock rims.
Old 04-27-2017, 10:50 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
I'm rocking 285/75/16 BFG AT/2 tires. They fit well under my truck with a leveling kit on V's up front and B's with the factory block in rear.
I had a few Options but was limited because of Discount Tire's policy on oversized tires.
295/75/16
305/70/16
315/75/16
I wanted 305's but they refused to mount them and would only mount the 285s or 295s without a problem.
I went with 285's because they're easy to find if I ever needed a replacement
Old 04-28-2017, 01:09 PM
6_Myles's Avatar
6_Myles
6_Myles is offline
285/75-16 on factories here too, but about to switch to the 18" HD wheels i scored.
Old 04-28-2017, 08:10 PM
Resto Guy's Avatar
Resto Guy
Resto Guy is offline
Will the factory spare tire cover fit over a 285/75-16? It's a butt kicker going over a 265!
Quick Reply: Tire size alternatives to 285/75R16s
