Manual Trans swap?
Old 04-25-2017, 11:17 PM
mtdorf's Avatar
mtdorf
mtdorf is offline
Manual Trans swap?
I have a 4 speed in my 59 f100 and I want to put in a 5 speed to lengthen the ol legs a bit. Has anyone done this? If so what, how, and pics please. I'm struggling to find a newer 5 speed that will bolt up to my transfer and rear driveline. I currently have a 72 360 powering the ol guy and will eventually drop in a rebuilt 390.
Thanks in advance.
Old 04-25-2017, 11:37 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
NV4500 would be a road already paved but you will still have to deal with building a driveline and a shifter for the T case. If you are doing an engine swap anyway, you might consider a 351 or 460 with the ZF and married transfer case.
I have access to a 460/ZF donor truck and am considering the swap into my 59. I would probably go carbureted which means swapping heads too.
Old 04-26-2017, 12:09 AM
mtdorf's Avatar
mtdorf
mtdorf is offline
Just have to jump in head first and get it done!! I haven't driven it in 5+years so I think it'll be staying the 4 for awhile longer, i just want to drive it LOL.
Thanks
Old 04-26-2017, 05:27 AM
Walston's Avatar
Walston
Walston is offline
While you are sorting it out. You can change the rear end from a 3.7:1 to a 3.00:1. You can then actually start in 1st gear instead of it being a granny and you can cruise at 70. Much easier and faster.
Old 04-26-2017, 09:49 AM
willowbilly3
I assume when mtdorf said transfer you meant transfer case which indicates four wheel drive and that would mean changing 2 gear sets. Also a lot will depend on tire diameter, camshaft selection ect.
Old 04-26-2017, 12:42 PM
Walston's Avatar
Walston
Walston is offline
Oops I missed that!
Austinleonard
11-10-2016 11:41 AM
flipboard7431
04-30-2014 07:30 PM
fordtrucker1984
03-04-2011 07:17 AM
86halfton
12-25-2009 04:01 PM
Ryan86F250
04-29-2003 08:22 PM
Quick Reply: Manual Trans swap?
