4R100 Transmission Parking Gear Press Fit
I recently purchased a used 4R100 4x4 output shaft with a reluctor ring and parking gear installed, and the parking gear is a little loose on the shaft. It moves about 20 thousandths axially on the shaft but there is no perceivable rotational motion.
As I understand it this gear is press-fit onto the output shaft so I expected it to be on there without any play. I figured it would be worth it to ask if this is an issue or if this is to be expected with a used assembly.
Thanks.
Thanks.
Thanks.
Thanks.
black58
19
06-11-2023 09:24 AM
rickdavis81
01-11-2016 11:13 AM
eldon
11-27-2006 05:45 PM
alwaysmessedup
05-21-2003 01:55 PM
