Filling diesel fuel tank right up to the top of the filler neck?
Since diesels don't have evaporative vapor emissions on the fuel tank, there's no worry of raw fuel being drawn into that system. Can the fuel tank in the Super Duty be filled plum-full right up to the top of the filler neck? Volkswagen owners refer to this as "venting", and you can get up to 2 gallons more than the capacity of the fuel tank, which is another 100 miles! Obviously on a hot day you want to get driving right away to keep fuel expansion from occurring, but it could mean less stops with 30 to 40 more miles per tank.
Yes it can be done, but depending on where Ford actually put the tank and if the same tank is designed to work with Gas and Diesel will greatly change how much "extra" it can hold. I'm coming over from the Ram Diesel market and the tank vent mod, relocating the vent to the highest spot of the expansion chamber, could net 5-6 not gallons in the factory tank.
on my 2004 I've ALWAYS filled the factory tank to the brim (I fill it until I see liquid, not foam).
On my 2004 6.0L I performed the in-tank Harpoon Mod....The Harpoon Mod really accelerated the tank fill on the 6.0L
when your burning a gallon every 12 or so miles it doesnt take long to pull the fuel down from the cap.
Diesel trucks don't have this system, so "fill it to the brim" if you have the time a patience to do so. For me, I do so to keep accurate records of fuel consumption.
[QUOTE=17 Oaks;17141585]
On my current truck I can put 50 gal in the 48 gal tank....[/QUOTE]
Go ahead Don, rub it in about that 48,,,no now its a 50 gallon tank! The short bed certainly got shorted in the fuel tank department, then to top it off they've made the fuel light come on about 75 miles sooner than it needs to which only give me about a 400-450 mile range if I'm not pulling. I wish Ford offered an optional extra capacity fuel tank. I certainly would have bought it.
[QUOTE=RJC2;17142340]
LOL, better it comes on early than comes on later...
My motorhome had a 150 gal diesel tank, on a trip I am about 20 mi outside El Paso when it shuts down, as if it was out of fuel...I check and no problem there I stull got fuel...or so I think. After some messing around I call tech support and we talk for a bit, try this, try that, wants to start but won't. Then I hear the DREADED words: 'Ohhh, I think they forgot to tell you'
TELL ME WHAT??
Well yes you have a 150 gal tank, but you can only access the first 100 gals and in make ready they should have checked to see if the computer was set for a 150 tank.
Is this some kind of sick joke???
That was the LAST STRAW, sold the beast, nevermore.
TELL ME WHAT??
[QUOTE=17 Oaks;17142923]
Shorting you 50 gallons! Now that's a major mistake. You didn't use any foul language did you.... Nooooo!
TELL ME WHAT??
TELL ME WHAT??
